cancel
Showing results for
Search instead for
Did you mean:
Nios2Colinux
Nios2Colinux
download
coLinux-0.6.3.exe
Gentoo-2005.1-stage3-ext3.bz2
swap_device is a file from http://gniarf.nerim.net/colinux/swap/
TUGZip: http://www.tugzip.com
toporesize-20040908.zip
run coLinux-xxxx.exe to install coLinux.
use tugzip to uncompress the gentoo filesystem image, and rename the image to root_fs ,in coLinux dir .
use toporesize to enlarge the image to 5GB or more.
uncompress swap file, use 256M or larger.
In coLinux dir, run coLinux , with memory usage setup to 256MB.
colinux-daemon mem=256 kernel=vmlinux hda1=root_fs root=/dev/hda1 hda2=swap_256Mb cofs0=c:\\\\ eth0=tuntap -t nt
Login root, password root.
turn on swap, or add swap to fstab<span id="fck_dom_range_temp_1285651207227_208" />
swapon /dev/hda2
Mount the windows drive c: with cofs on /mnt/xp,
mkdir /mnt/xp
mount -t cofs cofs0 /mnt/xp
Install nios2gcc toolchain. Binary Toolchain
Install uClinux-dist-test with patches for nios2 under /root dir. UClinuxDist
NOTE, the gentoo image does not contain Xserver and much tools. You will need to use "emerge" to add more packages.
Or you can use other image,
albertyong88 said, You can download blackfin-colinux (from blackfin uclinux wiki site), which is very easy to install. It has most tools you need. It also provides Xserver and stuff ...
You can then follow the wiki for installing Eclipse as your development platform if you are not confortable on using command text editor.
bigboss25 said, Or try using Colonist (http://colonist.sourceforge.net/) with Kubuntu Live image, which include KDE UI and some apps (OpenOffice, text editor ...). I use Xming as X server to display KDE desktop on my Windows desktop. Currently, it works well but is a bit slow.
Note that during install , Colonist will also create virtual drive for your Windows partitions, so you will be able from KDE to see all your windows drive ;o)
Configuring Xming X server is a bit tricky (it appears that your firewall must be disabled), but it works.
Version history
Last update:
‎06-25-2019 09:10 PM
Updated by:
Contributors
