cancel
Showing results for
Search instead for
Did you mean:
836 Discussions
PCI Express to External Memory - Stratix IV ALTMEMPHY DDR3 PCIe Gen1x8
Reference Design : PCI Express to External Memory - Stratix IV ALTMEMPHY DDR3 PCIe Gen1x8
Last Major Update
February 2010, Version 1.3 - Design updated to use DDR3 SDRAM High Performance Controller II (with ALTMEMPHY) IP with PCI Express Gen1x8 IP.
Design Overview
This PCI Express to External Memory reference design demonstrates the operation of Altera's PCI Express MegaCore® function with the ALTMEMPHY-based DDR3 SDRAM memory controller. This design provides a sample interface between the PCI Express Gen 1 x8 link and an external 64-bit SDRAM memory.
If you are looking for a PCIe Gen2 x8 to UniPHY DDR3 reference design, refer to Altera's PCI Express to External Memory Reference Design web page.
Design Specifications
The table below lists the specifications for the reference design:
AttributeSpecification
Quartus II version9.1 SP2
PCIe IPPCI Express Compiler v9.0
DDR3 IPDDR3 SDRAM High Performance Controller v9.1 SP2
Development KitStratix IV FPGA Development Kit - DK-DEV-4SGX230N
FPGA deviceEP4SGX230KF40C2
PCIe ConfigurationGen1 x8
DDR3 Interface Frequency533-MHz / 1066-Mbps
DDR3 Interface width64-bit (four x16 components with fly-by topology)
DDR3 memory deviceMT41J64M16LA-15E
Content
Notes/Comments
The PCIe MegaCore IP cannot be regenerated and must be used as-is. Regenerating the IP would erase all customizations made to the design to replace internal memory with an external memory interface.
Update History
  • February 2010, Version 1.3 - Design updated to use DDR3 SDRAM High Performance Controller II (with ALTMEMPHY) IP with PCI Express Gen1x8 IP.
See Also
External Links
  1. AN 431: PCI Express to External Memory Reference Design
  2. External Memory Interface Handbook: DDR3 SDRAM Controller with ALTMEMPHY IP User Guide
  3. PCI Express Compiler User Guide
Key words
DDR3, External Memory, PCIe, Stratix IV, Gen1x8, ALTMEMPHY
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-26-2019 10:54 PM
Updated by:
Contributors
