cancel
Showing results for
Search instead for
Did you mean:
Partial Reconfiguration Example Design with Flash
This is a PR example design developed on Stratix V FPGA Dev Kit using ACDS 13.1.
  • Internal host with bitstreams in Flash
  • Static region:
  • Nios II program PR bitstream into external flash
  • Total of 4 PR regions with each one contains of 2 personas:
  • Persona 1: slow blinking led
  • Persona 2: fast blinking led
  • Media:Pr_design_example_with_flash.zip
Here is a simpler design that only has 1 PR region with 2 personas
Out of Box Experience
  • The attached design is ready with compiled sof file and rbf file for each persona, if you want to hands on directly, skip to program the sof and flash. If you recompile the design, you might want to regenerate the updated rbf for the persona:
quartus_cpf -p output_files/s5gxea7_fpga_bup.x8y13.msf output_files/s5gxea7_fpga_bup.sof output_files/s5gxea7_fpga_bup.x8y13.pmsf
quartus_cpf -p output_files/pr.x8y13.msf output_files/pr.sof output_files/pr.x8y13.pmsf
quartus_cpf -c output_files/s5gxea7_fpga_bup.x8y13.pmsf output_files/s5gxea7_fpga_bup.x8y13.rbf
quartus_cpf -c output_files/pr.x8y13.pmsf output_files/pr.x8y13.rbf
bin2flash --input=output_files/s5gxea7_fpga_bup.x8y13.rbf --output=output_files/s5gxea7_fpga_bup.x8y13.flash --location=0x021C0000
bin2flash --input=output_files/pr.x8y13.rbf --output=output_files/pr.x8y13.flash --location=0x023C0000
quartus_cpf -p output_files/s5gxea7_fpga_bup.x18y27.msf output_files/s5gxea7_fpga_bup.sof output_files/s5gxea7_fpga_bup.x18y27.pmsf
quartus_cpf -p output_files/pr.x18y27.msf output_files/pr.sof output_files/pr.x18y27.pmsf
quartus_cpf -c output_files/s5gxea7_fpga_bup.x18y27.pmsf output_files/s5gxea7_fpga_bup.x18y27.rbf
quartus_cpf -c output_files/pr.x18y27.pmsf output_files/pr.x18y27.rbf
bin2flash --input=output_files/s5gxea7_fpga_bup.x18y27.rbf --output=output_files/s5gxea7_fpga_bup.x18y27.flash --location=0x025C0000
bin2flash --input=output_files/pr.x18y27.rbf --output=output_files/pr.x18y27.flash --location=0x027C0000
quartus_cpf -p output_files/s5gxea7_fpga_bup.x20y26.msf output_files/s5gxea7_fpga_bup.sof output_files/s5gxea7_fpga_bup.x20y26.pmsf
quartus_cpf -p output_files/pr.x20y26.msf output_files/pr.sof output_files/pr.x20y26.pmsf
quartus_cpf -c output_files/s5gxea7_fpga_bup.x20y26.pmsf output_files/s5gxea7_fpga_bup.x20y26.rbf
quartus_cpf -c output_files/pr.x20y26.pmsf output_files/pr.x20y26.rbf
bin2flash --input=output_files/s5gxea7_fpga_bup.x20y26.rbf --output=output_files/s5gxea7_fpga_bup.x20y26.flash --location=0x029C0000
bin2flash --input=output_files/pr.x20y26.rbf --output=output_files/pr.x20y26.flash --location=0x02AC0000
quartus_cpf -p output_files/s5gxea7_fpga_bup.x19y62.msf output_files/s5gxea7_fpga_bup.sof output_files/s5gxea7_fpga_bup.x19y62.pmsf
quartus_cpf -p output_files/pr.x19y62.msf output_files/pr.sof output_files/pr.x19y62.pmsf
quartus_cpf -c output_files/s5gxea7_fpga_bup.x19y62.pmsf output_files/s5gxea7_fpga_bup.x19y62.rbf
quartus_cpf -c output_files/pr.x19y62.pmsf output_files/pr.x19y62.rbf
bin2flash --input=output_files/s5gxea7_fpga_bup.x19y62.rbf --output=output_files/s5gxea7_fpga_bup.x19y62.flash --location=0x02CC0000
bin2flash --input=output_files/pr.x19y62.rbf --output=output_files/pr.x19y62.flash --location=0x02EC0000
  • Program the sof into the board
nios2-configure-sof output_files/s5gxea7_fpga_bup.sof
  • Program the flash before you run the partial reconfiguration
nios2-flash-programmer --base=0x0 --program output_files/s5gxea7_fpga_bup.x8y13.flash
nios2-flash-programmer --base=0x0 --program output_files/pr.x8y13.flash
nios2-flash-programmer --base=0x0 --program output_files/s5gxea7_fpga_bup.x18y27.flash
nios2-flash-programmer --base=0x0 --program output_files/pr.x18y27.flash
nios2-flash-programmer --base=0x0 --program output_files/s5gxea7_fpga_bup.x20y26.flash
nios2-flash-programmer --base=0x0 --program output_files/pr.x20y26.flash
nios2-flash-programmer --base=0x0 --program output_files/s5gxea7_fpga_bup.x19y62.flash
nios2-flash-programmer --base=0x0 --program output_files/pr.x19y62.flash
  • Select the persona using the switch, then press button (PB2) to initial the PR
0x0: LED2 to fast blinking
0x1: LED2 to slow blinking
0x2: LED4 to fast blinking
0x3: LED4 to slow blinking
0x4: LED5 to fast blinking
0x5: LED5 to slow blinking
0x6: LED6 to fast blinking
0x7: LED6 to slow blinking
  • Other LEDs:
LED0: blinking to show static region is running
LED1: indicate PR error
Version history
Last update:
‎06-27-2019 12:13 AM
Updated by:
Contributors
