cancel
Showing results for
Search instead for
Did you mean:
Practical CRC Usage
Practical CRC Usage
February 25, 2011
Last Updated
Description
This example attempts to illustrate some basic characteristics of the crc32 algorithm and suggests some practical applications that can be derived from them. The archive provided with this example contains a shell script that can be executed to produce the output shown below.
Contents
Download the archive and extract it using tar (tar xzf <archive_name>). Change into the example directory (cd practical_crc_usage) and then run the example script (./practical_crc_usage.sh). This example should run just fine on a Windows platform with the Altera 10.1sp1 development tools installed, including the Nios II software development tools. Open a Nios II command line shell and execute this example from the bash command prompt.
Version history
Last update:
‎06-27-2019 12:25 AM
Updated by:
Contributors
