cancel
Showing results for
Search instead for
Did you mean:
Programmable IOE Delay Chain Interface
The attached .zip file has a full project and simulation testbench for interfacing to the IOE programmable delay chain. There is also a User Guide that goes into detail on the implementation.
The basic concept is that the delay chains require user logic to control their configuration.  This design has a state-machine for doing this configuration, but also has a simple register map for controlling which I/Os are configured and what value they should be configured with.  This allows a system processor, whether on or off chip, to dynamically configure the delay chains through software rather than hardware.
The design also makes use of the half-rate registers.  As discussed, there currently are some obstacles in implementing these, so there is a simple parameter to bypass them.
 File:Programmable Delay Chain Interface.zip
Version history
Last update:
‎06-27-2019 12:34 AM
Updated by:
Contributors
