cancel
Showing results for
Search instead for
Did you mean:
Quartus for Debian Wheezy
Installation of Quartus on Debian Wheezy amd64 (Testing) from 13.12.2011
1. Install used library’s and tools
aptitude install ia32-libs ia32-libs-gtk libxerces-c28 zsh
2. Extract Quartus
./11.1sp1_216_quartus_free_linux.sh --noexec
3. Edit setup file
Edit first line of ./11.1sp1_216_quartus_free_linux/setup.sh
#! /bin/zsh
4. Add missing locales
dpkg-reconfigure locales -> Select all en_US
5. Setup Quartus
cd ./11.1sp1_216_quartus_free_linux/
./setup.sh
6. Stupid hack because altera forgot some libraries...
cd altera/11.1sp1/quartus/
cp /usr/lib/libxerces-c.so.28.0 linux64/libaxerces-c.so.26
cp /usr/lib/libicudata.so.48 linux64/libicudata.so.34
cp /usr/lib/libicuuc.so.48.1.1 linux64/libicuuc.so.34
7. Add group blaster and add user to group
addgroup blaster
adduser username blaster
8. Setup udev for USB-Blaster
-> http://www.altera.com/download/drivers/dri-usb_b-lnx.html (Changed for use of group / new udev)
Add the following lines to the /etc/udev/rules.d/51-usbblaster.rules file:
# USB-Blaster
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", GROUP="blaster"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", GROUP="blaster"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", GROUP="blaster"
# USB-Blaster II
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", GROUP="blaster"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", GROUP="blaster"
# BeMicro
SUBSYSTEM=="usb", ATTR{idVendor}=="0403", ATTR{idProduct}=="a4a0", GROUP="blaster"
9. (Optional) BeMicro Driver
Download driver from: http://www.arroweurope.com/markets-solutions/solutions/bemicro/bemicro.html -> Download Reference Design
Direct link: http://www.arroweurope.com/contact-us/bemicro-reg-thank-you.html
Extract the Archive and copy the driver:
cp driver/linux-x86_64/libjtag_hw_arrow.so altera/11.1sp1/quartus/linux64/
10. Paths
Add the folowing lines to your ~/.profile:
export QUARTUS_ROOTDIR="$HOME/altera/11.1sp1/quartus"
export QUARTUS_ROOTDIR_OVERRIDE="$QUARTUS_ROOTDIR"
export PATH=$PATH:"$HOME/altera/11.1sp1/quartus/bin"
export PATH=$PATH:"$HOME/altera/11.1sp1/nios2eds/bin"
export PATH=$PATH:"$HOME/altera/11.1sp1/modelsim_ase/bin"
Now you should log out and log in again. Then you can call all commands from a terminal. It is also possible to add the programs to the menue of Gnome. quartus and eclipse-nios2 works but vsim has to be called this way:
xterm -e vsim
11. GTK_PATH
If you get errors like:
Gtk-Message: Failed to load module "canberra-gtk-module": /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so: wrong ELF class: ELFCLASS64
GTK_PATH has to be set for the 32-Bit librarys. But this doesn't work global in .profile because then 64-Bit programs have problems. So the best way is to create startup scripts for quartus and eclipse-nios2 in ~/bin/:
#! /bin/sh
export GTK_PATH=/usr/lib32/gtk-2.0
~/altera/11.1sp1/quartus/bin/quartus
#! /bin/sh
~/altera/11.1sp1/nios2eds/bin/eclipse-nios2
12. Fix for sof2flash, elf2flash, elf2hex, bin2flash
These scripts are not compatible with dash, so modify the first line from #!/bin/sh to #!/bin/bash in the folowing files:
sof2flash elf2flash elf2hex bin2flash sh_jar.sh
Version history
Last update:
‎06-27-2019 12:46 AM
Updated by:
Contributors
