cancel
Showing results for
Search instead for
Did you mean:
Reconfig Design Example 1
Contents
 [hide
External Links
Altera Transceiver PHY IP Core User Guide (PDF)
Altera Stratix V Device Documentation
Altera Avalon Memory-Mapped Interface Specification (PDF)
Altera Reconfig Design File (ZIP)
Design Specifications
The table below lists the specifications for this design:
AttributeSpecification
Device FamilyStratix V GX
FPGA5SGXMA7K2F40C2
Quartus versionQuartusII v11.0, b157
Modelsim versionModelsim SE v6.6d
Datarate3.125Gbps
Data patternPRBS 23
Number of channels
IP usedCustom PHY IP, Traceiver Reconfiguration Controller
Design Overview
This design implements the following blocks:
  1. Custom PHY IP
  2. Transceiver Reconfiguration Controller
  3. PRBS Generator
  4. PRBS Checker
  5. Avalon Memory-Mapped (MM) Master
Simulation Guidelines
The attached zip file has all the required design and simulation files. To start the simulation, launch Modelsim and source phy_sim_top.tcl
Update History
  1. Initial Release - May 05 2011
 See Also
  1.  Transceiver design examples
Key Words
Stratix V, Custom PHY IP, Tranceiver Reconfiguration Controller
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-26-2019 10:20 PM
Updated by:
Contributors
