cancel
Showing results for
Search instead for
Did you mean:
SRIO gen2 reference design
Last Update
March 26, 2014
Reference Documents
RapidIO II MegaCore Function User Guide (PDF)
Downloadable Reference Design File
Rio2_2x_6250_sys_sv_es_12_1sp1.qar
Introduction
The purpose of this design is to demonstrate how to use Altera Serial RapidIO IP Core pass-through port to generate and receive different type of packet. The reference design is running at x2 modes 6.25 Gbaud data rate. It can be change to any different modes and data rate easily re-generate the Serial RapidIO IP Core.
The design targets the Stratix V GT Signal Integrity Evaluation Board (Stratix V GT device 5SGTMC7K2F40C2) and is developed with the Altera Quartus II release 13.1 development tool.
This reference design able to generate the following RapidIO transactions types:
1) NREAD
2) NWRITEs (non-shareable memory write operations)
3) SWRITEs (streaming write, double-word only version of NWRITE with less header overhead)
4) Maintenance Read
5) Maintenance Write
6) Maintenance Port Write
7) Doorbell Messages
8) Message packet
9) Response packet w/o data
10) Response packet with data
Note:
1. The reference design dose not able to response to the request packet such as Doorbell, Message, Nread or Maintenance Read and write packets.
2. The reference design is provided as is and is not supported by Altera.
High Level Architecture
Figure 1-1 shows a top-level block diagram of the RapidIO reference design implemented on the Altera FPGAs.
 5/5d/Passthrough_top.png
Figure 1-1 FPGA Reference Design
The Control Unit is system console. The Control Unit runs at a lower frequency than the rest of the design. For the 6.25 Gbaud x2 solution, the RapidIO core runs at 156.25 MHz. The Control Unit had difficulty using this clock speed and this is the reason it was designed as a separate block. In this design the Control Unit is running at 50MHz.
Control Unit
The following are components used in the Control Unit and a description of their function.
System Console
Altera's System Console is a TCL console that provides access to hardware modules instantiated in FPGA. It can create powerful verification instruments for the system. It can start, stop or step different procedure to read or write Avalon Memory-Mapped (Avalon-MM) slaves. It can also run JTAG loopback tests. System Console is intended as a low level tool for tasks such as board bring up and device driver debugging.
JTAG Avalon
This component provides the mechanism for communicating to the System Console. The System Console is the user interface to the RapidIO IP and test application registers.
Avalon_mm_read_combine
Various bridges that allow communication of the single master port of JTAG Avalon MM port with multiple components with like sRIO IP Core, packet generator and checker etc, by the using of Address Mapping. These are described in more detail in the section, “Testing the Reference Design” and memory mapping.
RX_BUFFER
This module terminates write bursts and services read bursts which are a result of NWRITEs or NREADs being received by the RapidIO core. The module has a local 32x8Kbyte memory.
RapidIO MegaCore
The RapidIO MegaCore is the main component in this reference design. It is responsible for establishing a RapidIO link with the link partner. It will also convert the transactions presented to it on the Avalon-MM interfaces into the corresponding RapidIO transactions and transmit them on the RapidIO serial link. On reception, it will convert the RapidIO transactions into Avalon-MM bursts and present these bursts to the corresponding Avalon-MM Slave or Master interfaces.
Pass-through test Logic
Pass-thru port is a custom interface provided by SRIO core to handle packet types/transaction types other than those that it supports. If the SRIO core does not support the type of the packet that it has been asked to receive, then that packet is routed to the Pass-through port rather than the IO Master port. For transmit, the Custom Logical layer is directly connected (rather than routed) to the Pass-through port. The Pass-through test logic is used to test the performance on Pass-through port of RapidIO core. The main components of pass-through test logic are Custom Logical layer (created using the IO Master verilog files) and Pass-through RX_BUFFER. Custom logical layer will directly connect to the Transport layer of RapidIO core through Pass-through port. For more information, please refer SRIO_FPGA_Functional_Document.doc.
All of the files, necessary for testing this reference design are included in the zip file “Pass_through_srio_6250_2x_systemconsole_13_1.zip”.
Un-unzip the Quartus II 13.1 Project
Download and un-zip the Pass_through_srio_6250_2x_systemconsole_13_1.zip file. After unzipping, you will have the following folder structure. Please refer Figure 2-1 : Extracted Packet File image.
 d/d7/Passthrough_unzip.png
Figure 2 1 Extracted Packet File image
Package Content Description
After extraction, there is a folder named “Pass_through_srio_6250_2x_systemconsole_13_1”.
Folders Description:
JTAG_AVALON: JTAG Avalon module
Phy_mgmt_pll_125: 125MHz pll module
Sys_pll_156: 156MHz pll module
Rio2_2x_6250: sRIO IP Core
Srio_reconfig_ctrl: Reconfiguration Control module
System_console: System_console tcl file
Files Description:
Rio2_hw.v: Top level file
Passthrough_test_logic.sv: Traffic generator and packet checker
Avalon_mm_read_combine.v: Avalon MM read/write hop
GUI Interface and Memory Mapping
This section will introduce the GUI interface.
Note: System Console have to open after program FPGA.
Open System Console
Step 1: Open System Console under Tool -> System Console -> System Console
 6/62/Passthrough_systemconsole.png
Figure 3-1 Open System Console
Step 2: Type “cd system_console” and “source main_run.tcl” command to execute the Tcl file and run the GUI interface. See example below.
 d/dc/Passthrough_system_console.png
Figure 3-1.1 Open System Console
GUI Control Panel
There are two control panels in the GUI. Status_Register control panel and Packet Generator control panel.
Status_Register control panel includes port status & control register and soft-error recovery relative registers. See figure 3-2.1.
Note:
1. Make sure Port_OK LED light is “green” which means port is link up.
2. OutPort_Enable and InPort_Enable need to be set to 1 in the “Port Control Register” before generate packets.
Packet Generator control panel includes packet parameter setting register, TX packet counters and RX packet counters. See figure 3-2.2.
 0/0e/Passthrough_GUI_status.png
Figure 3 2.1 Status Register Control Panel
a/aa/Passthrough_GUI_packet_gen.png
Figure 3 2.2 Packet Generator Control Panel
Tcl Console Command
There are two basic read/write commands available for the Tcl Console to read/write particular register.
Reg_read 0xaddress //Register Read
Reg_write 0xaddress 0xdata //Register Write
Memory Map
 e/e8/Passthrough_memory_map1.png
/7/73/Passthrough_memory_map2.png
Figure 3-4 Memory Map
Test Steps
Some steps need to be done before generate packets:
1. Use the “Status_Register” Panel. (See Figure 3 2.1)
2. Check “Port Status Register” port_OK bit is asserted.
3. Check “Port Control Register” port width linkup with 2X mode.
4. Enable input and output port enable bits in “Port Control Register”. That allow data packet go through.
5. Use the “PakcetGenerator” Panel. (See Figure 3 2.2)
6. This panel allows you to generate and receive packet.
7. Configure the packet as below.
NWrite Packet
Following header setting need to be done before start the NWRITE transaction test:
1. Set “Pkt Type” to NWrite.
2. Set “Payload Size”.
3. Set “DestID” number.
4. Set “Transction ID”, optional.
5. Set “Tx Address”, optional.
6. Set “Payload Data”, optional, 32bit.
Data structure is fixed for NWrite packet
Pd_data = {Pakcet counter (4byte), 0’s (2byte), Payload_Data[31:16], Payload_Data…}
Transcetion ID will increment automatically from 0x80 to 0xFF.
SWrite Packet
Following header setting need to be done before start the SWRITE transaction test:
1. Set “Pkt Type” to SWrite.
4. Set “Tx Address”, optional.
5. Set “Payload Data”, optional, 32bit.
Data structure is fixed for SWrite packet
Pd_data = {Pakcet counter (4byte), Payload_Data, Payload_Data, …}
DoorBell Packet
Following header setting need to be done before start the Doorbell transaction test:
1. Set “Pkt Type” to DoorBell.
2. Set “DestID” number.
3. Set “Transction ID”, optional.
4. Set Information at Tx Address[15:0] field.
Maintenance Read
Following header setting need to be done before start the Maint Read transaction test:
1. Set “Pkt Type” to Maint Read.
3. Set “Transction ID”.
4. Set “Hop count” number.
5. Set “Tx Address” [23:0] 24bit.
Maintenance Write
Following header setting need to be done before start the Maint Write transaction test:
1. Set “Pkt Type” to Maint Write.
5. Set “Tx Address”.
6. Set “Payload Data” 32bit.
Port Write
Following header setting need to be done before start the PortWrite transaction test:
Receive Maintenance Read Response Packet
“Packet Generator Setting” Panel -> “Read” button will read the last maintenance read response packet data which shows on “Maint Read Data” 64bit long.
Message Packet
Following header setting need to be done before start the Message transaction test:
3. Set 4bit Len, 4bit Size, 2bit letter, 2bit Mbox, 4bit message in “Tx Address” field. Total of 16bit.
4. Set “Payload Data” 32bit.
Response Packet w/o Data
7. Set “Pkt Type” to Maint Write.
8. Set “DestID” number.
9. Set 4bit Status, and 8bit targetID in “Tx Address” field. Total of 12bit.
Response Packet with Data
10. Set “Pkt Type” to Maint Write.
11. Set “DestID” number.
12. Set 4bit Status, and 8bit targetID in “Tx Address” field. Total of 12bit.
13. Set “Payload Data” 32bit.
Note: All packet generator setting needs to press “Write” button to write to the register.
Disclaimer
© [2014] Altera Corporation. The material in this wiki page or document is provided AS-IS and is not supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable, misleading or inaccurate.
Version history
Last update:
‎06-26-2019 09:02 PM
Updated by:
Contributors
