cancel
Showing results for
Search instead for
Did you mean:
834 Discussions
Scalable Multispeed 10M-10Gbps Ethernet without 1588 using 1G/10G PHY Design Ex
Scalable Multispeed 10M-10Gbps Ethernet without 1588 using 1G/10G PHY Design Example
Last Major Update
December 11, 2013
Introduction
This note describes a demo design that demonstrates the functionality of the Altera Multispeed 10M/100M/1G/10Gbps Ethernet (MAC +1G/10G PHY) IP which able to support for 4 speeds in both manual and automatic mode. Stratix V SI hardware kits will be used for the demo.
Software and Hardware Requirements
Altera uses the following hardware and software to test the scalable Quadspeed Ethernet design example and testbench:
■ Altera Complete Design Suite 13.1 IB162
■ Stratix V GX Transceiver SI Development Board (EP5SGXEA7N2F40C2N)
■ ModelSim-SE 10.2b
■ VCS 2013.06-1
■ USB-Blaster cable
■ Windows- or Linux-based system console
■ Clock control ( refer to http://www.altera.com/products/devkits/altera/kit-transceiver-si-stratix-v.html to install the Kit installation for v11.1.2 )
Procedures to run the hardware design
The design example package comes with pre-generated RTL files which can support up to 12 channels. To use the design example, perform the following steps:
1. Download and unzip the demo project: Altera_eth_1g10g_lineside.zip
2. Download the altera_eth_top.sof file provided into Stratix V SI board.
3. After download the .sof file, open the clock control and change the target frequency setting as below (refer to Figure 1 and Figure 2):
Y3 - 322.2656 MHz
Y4 – 125MHz
8/83/Figure4and5_clockcontrol_1G10G.png
4. Press PB0 push button to reset the system. System must be hard reset before proceed. NOTE: The pin assignment, device setting and register map for 12 channels have been set in .qsf file).
5. Launch system console from Qsys.
6. Browse to the SystemConsole_wo1588 directory in the System Console command shell.
7. Type the command “source main.tcl “ followed by ENTER key to launch the reference design command list.
8. User can refer to the test functions available in main.tcl file to perform the following tests:
i) TEST_PHYSERIAL_LOOPBACK {channel speed_test burst_size} - PHY internal serial loopback
ii) TEST_SMA_LB {channel speed_test burst_size} - SMA loopback
iii)TEST_1588 {from_channel to_channel speed_test} - SMA loopback between 2 channels (1. master ,2 Slave).
9. For more detail information related to this design example, please refer to the Scalable_1G10GbE_Design_Example_User_Guide
Disclaimer
© [2011] Altera Corporation. The material in this wiki page or document is provided AS-IS and is not supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable, misleading or inaccurate.
Version history
Last update:
‎06-26-2019 09:12 PM
Updated by:
Contributors
