Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
0 / 5 (0 votes cast)
Added GT channel spreadsheet - April 12th 2012
Stratix V transceiver buffers have several circuits to condition the signal before it is transmitted. These include programmable output voltage (Vod) controls and a 3 tap programmable pre-emphasis (2 taps with GT channels). Certain combinations of these programmable settings are deemed illegal by Altera because they result in the output buffer being over or under-driven, or the expected buffer behavior cannot be guaranteed across PVT. The Quartus fitter knows these illegal settings and will flag an error if the transceiver IP is configured as such. The transceiver toolkit's auto-sweep function also knows which settings are illegal and will not check those settings. However, the toolkit's manual mode and the transceiver dynamic reconfiguration IP does not check for the legality of the PMA settings. This is so users can access the entire setting space for investigation or research purposes. Altera does not support the use of the illegal settings for production as Altera cannot guarantee output buffer performance.
The Stratix V PMA Setting Check spreadsheet can be useful when using the toolkit or reconfiguration IP to manually set the Vod or pre-emphasis. The GX channel spreadsheet can be found here:
a/a8/SV_GX_PMA_setting_check.zip
The GT channel spreadsheet can be found here:
e/e6/SV_GT_PMA_setting_check.zip
Stratix V PMA legal illegal settings Vod Pre-emphasis check tool
© 2012 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
