cancel
Showing results for
Search instead for
Did you mean:
Superloop Simple Socket Server Plus
(Redirected from SuperloopSimpleSocketServerPlus)
Last Updated
September 7, 2011
Description
The Superloop Simple Socket Server Plus example is a Superloop implementation of the Simple Socket Server Plus (SSS Plus) example that is also published on the Nios Wiki site. This example has all of the features and capabilities of the SSS Plus example however it is implemented with the Superloop option that is built into the InterNiche TCP/IP stack such that it does not require an RTOS for the application to run. This is a basic capability that is available in the InterNiche TCP/IP stack as it ships with the Altera Nios II development environment.
Contents
The current version of this example has been ported to the 3C120 Altera development board.
3C120 port for 11.0sp1
There is a development archive if you are interested in seeing the source code for the software application, building the source into a software application and running the application on the 3C120 hardware design that it is currently ported to.
There is also an executable binary archive available which you can extract and run immediately on a 3C120 development board.
There are some outdated PDF documents that explain how to use the SSS Plus application once you have it up and running on a 3C120 board, as well as a technical discussion about how the application is put together and what user modifications are possible to adapt the application into another implementation. This documentation was originally created for the 9.0sp1 release and is still quite applicable to this 11.0sp1 release, the reader should only notice mild discrepancies.
BeMicroSDK port for 11.0sp1
There is a development archive if you are interested in seeing the source code for the software application, building the source into a software application and running the application on the BeMicroSDK hardware design that it is currently ported to.
There is also an executable binary archive available which you can extract and run immediately on a BeMicroSDK development board.
Instructions
Downloading the example
Download the archives you are interested in and place them in a directory on your system that does not include spaces in the path name. The entire path name of this directory must not contain spaces, so on Windows systems you should avoid putting these in the "My Documents" folder, or on your "Desktop" since these locations are subdirectories of the "Documents and Settings" path, and that would mean that these locations inherit the spaces in that part of the path name.
In order to extract the archives after downloading them, it is recommended that you run the "tar -xzf <filename>" command from a bash shell. For linux users you should have ready access to a bash shell. For windows users, you may need to install the Altera development tools to gain access to a bash shell. On Windows it is recommended that you install the Altera Quartus II FPGA development tools along with the IP base suite as well as the Nios II EDS development tools. Once these tool chains are properly installed on your workstation, you can launch a bash shell by running:
"Start -> Programs -> Altera -> Nios II EDS X.0 -> Nios II 9.0 Command Shell"
Once you are in the bash shell, you can "cd" into the directory containing the archives that you've downloaded, and running the following commands to extract them:
tar -xzf <archive_filename>
Note that if you use some other archiving software to extract these archives, like WinZip, you may loose the execution privileges on some of the shell scripts within the archives that are used to perform various activities associated with building and using the example. If this happens, you can restore execute privileges from within a bash shell with the command "chmod +x <filename>". It is recommended that you avoid this situation by using "tar" to extract the archives from within a bash shell and avoid using any Windows oriented archive utilities with these archives.
Using the examples
After you have extracted the archive you should be able to locate a "readme.txt" within the archive directory that will give you some guidance on how to get started with that particular archive.
Requirements
3C120 port
This software application is currently ported to a hardware design example for the Altera 3C120 development board. This board is currently available in many different bundled packages today that go by these names:
  • Cyclone III FPGA Development Kit
  • DSP Development Kit, Cyclone III Edition
  • Embedded Systems Development Kit, Cyclone III Edition
Any one of the above development kits should contain the 3C120 base board that this example design is intended to run on.
Ethernet connection
Please note that if you are using a 3C120 board configuration that provides multiple Ethernet connectors, this example is created to use the Ethernet connector on the main base board, the board with the 3C120 device mounted on it. Do not connect the Ethernet cable to ports that extend off the HSMC connectors.
The current version of this example has been tested under the 11.0sp1 release of the Altera development tools.
BeMicroSDK port
This software application is currently ported to a hardware design example for the BeMicroSDK development board.
NEEK port (legacy)
This software application is currently ported to a hardware design example for the NEEK development board.
The current version of this example has been tested under the 9.0 SP1 release of the Altera development tools.
See Also
The Simple Socket Server Plus example, an RTOS based example which this example is derived from.
The 3C120 dev board hardware design example that this software application is ported to run on.
The NEEK dev board hardware design example that this software application is ported to run on.
Update History
20110907 - Posted an 11.0sp1 version of the Superloop SSS Plus 3C120 port. This was a clean recreation of the Superloop implementation of the 11.0sp1 version of the SSS Plus example. Also posted a port of this example to the BeMicroSDK development board.
20090614 - Updated with changes applied to the SSS Plus example to make the Superloop version. Please see the SSS Plus page for the changes that were applied to this release.
20090612 - Posted Superloop SSS Plus port for NEEK dev board.
20090526 - Initial posting, Superloop SSS Plus for the 3c120 dev board.
Outdated Releases
3C120 port for 9.0sp1
And then there is a flash programming archive that provides scripts that create flash images of the hardware and software application and can program them into the CFI flash of the 3C120 board so they will execute upon power up of the development board.
There are also a couple of PDF documents that explain how to use the SSS Plus application once you have it up and running on a 3C120 board, as well as a technical discussion about how the application is put together and what user modifications are possible to adapt the application into another implementation.
NEEK port for 9.0sp1
There is a development archive if you are interested in seeing the source code for the software application, building the source into a software application and running the application on the NEEK hardware design that it is currently ported to.
There is also an executable binary archive available which you can extract and run immediately on a NEEK development board.
And then there is an SD card archive that provides the executable images that can be copied onto the NEEK SD card and run on the board like any other NEEK application.
There are also a couple of PDF documents that explain how to use the SSS Plus application once you have it up and running on a NEEK board, as well as a technical discussion about how the application is put together and what user modifications are possible to adapt the application into another implementation.
3C120 release from 20090526
© 2011 Altera Corporation.
The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own
risk; it might be, for example, objectionable, misleading or inaccurate.
Version history
Last update:
‎06-26-2019 07:17 PM
Updated by:
Contributors
