cancel
Showing results for
Search instead for
Did you mean:
Tips for Incremental Compilation and LogicLock
This document describes various tips for using Incremental Compilation and LogicLock.
File:Tips for IncrementalCompilation LogicLock.pdf
Here is the Table of Contents for reference:
Table of Contents
Introduction 3
Timing Analysis 3
 Tip – Analyze paths from/to the source and destination of critical path 4
 Tip – Locate multiple paths to the Chip Planner 6
 Tip – Create a .tcl script to monitor critical paths across compiles 7
Incremental Compilation and LogicLock – Brief Overview 7
 Tip – Monitor area and slack differences when adding partitions 8
 Tip – Optimize Screen Space for LogicLock and Design Partition Windows 8
Basic Incremental Compilation Tips 9
 Tip: Quick Block Stitch with Partitions 9
 Tip: Create a Black-Box for Incomplete or Invalid Logic 11
 Tip: Put Non-Altera IP into Empty Partition 12
 Tip: Create Empty Partitions to Save Space 12
 Tip: Put Hierarchy Being Modified into a Partition for Quick Compiles 13
 Tip: Set the Top level partition to Post-fit when using SignalTap 13
 Tip: Partition I/O Interfaces 14
Incremental Compilation for Isolating Hierarchies 14
 Tip: Get as Much Margin as Possible When Designing Blocks 15
 Tip: Hierarchy Isolation Method 1 - Set Partition Top to Empty 16
 Tip: Hierarchy Isolation Method 2 - Set Adjacent Partitions to Empty 17
Incremental Compilation for Performance 18
 Tip: When Preserving Performance of a Partition, Create a .qxp 19
 Tip: Incremental Compilation for Performance Method 1: Building Up a Design 20
 Tip: Incremental Compilation for Performance Method 2: Isolating Multiple Partitions 21
 Tip: LogicLock when Preserving Performance with Incremental Compilation? 22
Floorplanning with LogicLock Regions 23
 Tip: Floorplanning I/O Interfaces 24
 Tip: Floorplan for Incremental Compilation on a Single Hierarchy 25
Floorplanning the Entire Design for Incremental Compilation 26
 Tip: Do not create too many Design Partitions or LogicLock Regions 27
 Tip: Avoid over-using Floating or Auto-Sized LogicLock regions 27
 Tip: Right-Click Locate Hierarchies from Project Navigator to Chip Planner 28
Floorplannining for Performance 29
Low-Level Floorplanning 29
 Tip: Putting critical paths in a LogicLock Region usually does not improve timing 29
 Tip: Over-Constraining 30
High-Level Floorplanning 31
 Tip: Think Up-Front If Design Can Be Floorplanned 31
 Tip: Use Block Diagram 33
 Tip: Analyze the Unfloorplanned Fit 33
 Tip: Keep It Simple 35
 Tip: Over Floorplan when Obvious 36
 Tip: Floorplan to Break Timing 37
 Tip: Add set_false_path to Test How Potential Modifications Effect Overall Fit 38
Conclusion 39
Version history
Last update:
‎06-26-2019 12:48 AM
Updated by:
Contributors
