Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
You may try out the uClinux on your Altera Nios dev board before compiling anything. You can learn how to run a compiled program on your board. It is a very basic and important step. The kernel image was built from uClinux-dist with the default config. Both the sof and ptf files come from the example project, and there is no change. The sof and kernel image version must match, otherwise it will not run.
Please check UClinuxDist for booting up message and usage. After you get uClinux boot up successfully, you can build the kernel image with the ptf file of the same hardware project.
You will need Quartus and Nios2eds installed. Download the sof and zImage files for your board to a working dir, eg c:download on Windows or ~/download on Linux. Note the drives mapping in Nios II command shell (cygwin), drive c: is named as /cygdrive/c/ and c:download is /cygdrive/c/download.
Open a Nios II command shell on Windows from Windows Start-->Programs-->Altera-->Nios II 7.2 -->Nios II Command Shell, and change to the download dir.
cd /cygdrive/c/download
Or open a shell terminal on Linux and change to the download dir.
cd ~/download
Note: If you don't have a Nios II license and have generated the .sof file yourself then its usage will be restricted. Follow the following instructions but run the nios2-configure-sof instruction from one command shell and run the nios2-download and nios2-terminal instructions from another. This allows the nios2-configure-sof to keep in contact with the processor so as to allow it to keep running.
step 1. Configure the FPGA,
nios2-configure-sof DE2_NIOS_HOST_MOUSE_VGA.sof
step 2. Download and run the kernel image,
nios2-download -g zImage DE2 NIOS HOST MOUSE VGA v1.6
nios2-terminal
The kernel image was built with File:DE2 NIOS HOST MOUSE VGA.ptf (was system_0.ptf) in the project DE2_System_v1.6/DE2_demonstrations/DE2_NIOS_HOST_MOUSE_VGA of the Terasic Download Center.
Download:
nios2-configure-sof DE2_70_NIOS_HOST_MOUSE_VGA.sof
step 2. Download and run the kernel image, nios2-download -g zImage_DE2_70_NIOS_HOST_MOUSE_VGA_v1.1 nios2-terminal
The kernel image was built with File:DE2 70 NIOS HOST MOUSE VGA.ptf (was DE2_70_SOPC.ptf) in the project DE2_70_SYSTEM_cd_v1.1/DE2_70_demonstrations/DE2_70_NIOS_HOST_MOUSE_VGA of the Terasic Download Center.
Download:
step 1. Configure the FPGA, nios2-configure-sof DE1_SD_Card_Audio.sof
nios2-download -g zImage_DE1_SD_Card_Audio_v0.6 nios2-terminal
The kernel image was built with File:DE1 SD Card Audio.ptf (was system_0.ptf) in the project DE1_CD_v0.6/DE1_demonstrations/DE1_SD_Card_Audio of the Terasic Download Center.
Download:
Easiest way to run Linux on the NEEK:
step 1: Copy the unzipped content of theFile:NEEK-uCLinux-eek.zip file as a subdirectory ("uCLinux") into the "Altera_EEK_Applications" directory on the SD-card provided with the kit.
step 2: With the Application Selector you now can select and start "uCLinux"
View the embedded file info.txt (e.g. in the Application Selector) to see what it can do and how it's done.
Another Application Selector Application is File:SLS Console.zip uploaded with permission of SLS Corp. This distribution shows the Linux starting messages on the NEEK's LCD screen and opens a shell that is displayed on the LCD screen and can be used with a PS2 keyboard attached to the NEEK.
Without using the SD-Card you can do this:
step 1. Configure the FPGA nios2-configure-sof cycloneIII_embedded_evaluation_kit_web_server.sof
nios2-download -g zImage_cycloneIII_embedded_evaluation_kit_web_server nios2-terminal
The kernel image was built with File:CycloneIII embedded evaluation kit web server sopc.ptf in the Cyclone III Embedded Evaluation Kit Web Server files.
However, the TSE MAC driver is not ready yet, and the ethernet won't work.
Download:
step 1. Configure the FPGA, nios2-configure-sof cycloneIII_embedded_evaluation_kit_web_server.sof
step 2. Download and run the kernel image, nios2-download -g zImage_cycloneIII_embedded_evaluation_kit_web_server nios2-terminal
However, the ethernet won't work as there isn't one on this board.
Useful wiki page: Cyclone III - Nios II - Starter board
Download:
step 1. Configure the FPGA, nios2-configure-sof cycloneIII_3c120_dev_niosII_standard.sof
nios2-download -g zImage_cycloneIII_3c120_dev_niosII_standard nios2-terminal
The kernel image was built with File:CycloneIII 3c120 dev niosII standard sopc.ptf in the cycloneIII_3c120_dev_kit-v7.2.3_CDROM.zip Via FTP.
However, the ethernet won't work as there isn't one on this design example.
Download:
step 1. Configure the FPGA, nios2-configure-sof NiosII_cycloneII_2c35_full_featured.sof
step 2. Download and run the kernel image, nios2-download -g zImage_NiosII_cycloneII_2c35_full_featured_v7.2 nios2-terminal
The kernel image was built with File:NiosII cycloneII 2c35 full featured sopc.ptf in the Nios2eds v7.2 installation dir, nios2eds/examples/verilog/niosII_cycloneII_2c35/full_featured.
Download:
step 1. Configure the FPGA, nios2-configure-sof NiosII_cyclone_1c20_full_featured.sof
nios2-download -g zImage_NiosII_cyclone_1c20_full_featured_v7.2 nios2-terminal
The kernel image was built with File:NiosII cyclone 1c20 full featured sopc.ptfin the Nios2eds v7.2 installation dir, nios2eds/examples/verilog/niosII_cyclone_1c20/full_featured .
Download:
step 1. Configure the FPGA, nios2-configure-sof NiosII_stratixII_2s60_RoHS_full_featured.sof
step 2. Download and run the kernel image, nios2-download -g zImage_NiosII_stratixII_2s60_RoHS_full_featured_v7.2 nios2-terminal
The kernel image was built with File:NiosII stratixII 2s60 RoHS full featured sopc.ptf in the Nios2eds v7.2 installation dir, nios2eds/examples/verilog/niosII_stratixII_2s60_RoHS/full_featured .
But the ethernet port on 2S60 may not work , due an issue in the design file v7.2.
Download:
step 1. Configure the FPGA, nios2-configure-sof NiosII_stratix_1s10_full_featured.sof
nios2-download -g zImage_NiosII_stratix_1s10_full_featured_v7.2 nios2-terminal
The kernel image was built with File:NiosII stratix 1s10 full featured.ptf in the Nios2eds v7.2 installation dir, nios2eds/examples/verilog/niosII_stratix_1s10/full_featured .
Download:
step 1. Configure the FPGA, nios2-configure-sof NiosII_stratix_1s40_full_featured.sof
step 2. Download and run the kernel image, nios2-download -g zImage_NiosII_stratix_1s40_full_featured_v7.2 nios2-terminal
The kernel image was built with File:NiosII stratix 1s40 full featured.ptf in the Nios2eds v7.2 installation dir, nios2eds/examples/verilog/niosII_stratix_1s40/full_featured.
Download:
If you are using time-limited sof , read opencore plus http://www.altera.com/literature/an/an320.pdf
Tethered Mode
Tethered mode requires an Altera serial joint test actions group (JTAG) cable connected between the JTAG port on your board and the host computer, which runs the Quartus II Programmer for the duration of the hardware evaluation period. The Quartus II Programmer only requires a minimum installation of the Quartus II software—no license is required.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
