GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
399 Discussions
ARC B580 Tomb Raider 9 low fps(only 54fps) with tressFX
Sean2025
Hi,I found there are some mistakes in playing Tomb Raider 9 with Arc B580. The fps would decresing so fast from 217fps to 54fps when I use tressFX in hair setting!!.Could you solve this problem?.
1.Maxsun OC 12GB B580
2.Game is coming from Steam
3.this problem is stable
4.perform DDU when updating to driver version 32.0.101.6557.I always do in this way.
5.setting is 2560x1440P,highest setting.
I attach two capfamex.json.One(08T0623) is the 217fps result without tressfx,other one(08T089) is the 54fps result with tressfx.
