Hello. I just bought an ARC b580 and ran into a problem. My sound is subtracting or "freezing". This is very noticeable and hinders the process. I want to say my system. These are the jginyue x99, xeon 2680v4 and the Behringer umc202hd sound card, the video card is connected via DP. There is a feeling that this error occurs only with the umc202, and when I directly connect the speakers, this does not happen, that is, in the audio input of the case or the motherboard. I have already tried 3 versions of Intel Arc drivers, the latest UMC driver is installed, without the UMC driver too, it is worth saying that there was no such problem with gtx650, gtx1660, radeon 6900 xt. It's also worth clarifying: I tried different sound bitrate settings, turned on rebar, turned off csm, turned off the serial port, and changed the usb ports of the sound card. Unfortunately, it didn't help. These rare additions don't go away.
- Tags:
- b580
Update: the problem is directly related to ReBar. When turned off, there are no lags, the sound coming out of the sound card works correctly, but the problem is already starting to be that without rebar, for example, in cyberpunk 2077 out of 60 stable fps 1440p, I get 30. In other words, performance drops significantly. It becomes impossible to play with it the same way. Please search for information on optimization and problems related to usb, sound cards, or any other PC attributes that may be incompatible with rebar.
