OpenCL* for CPU
1719 Discussions
OpenCL vectorisation issue in OneAPI driver
OCLdev
The OneAPI CPU OpenCL drivers (2021.12.6.0.19_160000) seem to have an issue with vectorization resulting in corrupted data. This simple kernel:
__kernel void test(__global float *f, __global float *r) {
int i = get_global_id(0);
r[i] = 0.0;
if (f[i] == 1.0F) {
r[i] = 1.0F+pow(1.0F, 1.0F);
when run over a buffer of length 16 with f equal to:
1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1
results in the following values in r:
2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 3126, 0, 0, 0, 0, 3126
Note the odd 3126 values. Turning off vectorisation using
CL_CONFIG_CPU_VECTORIZER_MODE=1
Results in the correct values:
2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 2
The issue seems to be caused by adding a value to the function (i.e. here 1.0+pow()), for example this gives an expected result:
r[i] = 0.0;
if (f[i] == 1.0F) {
r[i] = pow(1.0F, 1.0F);
This is on a Ubuntu 18.04 VM with an Intel(R) Core(TM) i7-6800K.
Is there anywhere I can raise a bug report/ticket? Or is this the correct forum to report?
VarshaS_Intel
Could you please provide the details of the compiler you are using and complete reproducer code with the steps to reproduce the issue?
You can post your queries related to OpenCL in this forum.
Link to the Forum: https://community.intel.com/t5/GPU-Compute-Software/bd-p/gpu-compute-software
Thanks & Regards
Varsha
OCLdev
Hi Varsha,
Thanks for getting back. I should start by saying I tried this on an Ubuntu F4s_v2 (Intel Xeon 8272CL) VM on Azure and had no issues. The above came from an Ubuntu VM running on VMWare on Windows (on a Intel Core i7-6800K). So it might be related to just this particular unusual combination. I'll post the steps to run the test in case you need them:
  1. Create Ubuntu 18.04 VM.
  2. Update VM:
    sudo apt-get update
  3. Install g++ and pocl to build:
    sudo apt-get -y install g++ ocl-icd-opencl-dev opencl-headers libpocl2
  4. Copy OpenCL_test.cpp and cl2.hpp to VM.
  5. Compile test program:
    g++ OpenCL_test.cpp -o test /usr/lib/x86_64-linux-gnu/libOpenCL.so
  6. Run test:
    azure:~$./test
    Platform: Portable Computing Language
    OpenCL: Build log:
  7. Install Intel OpenCL:
    wget https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
    sudo apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
    rm GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
    sudo add-apt-repository "deb https://apt.repos.intel.com/oneapi all main"
    sudo apt update
    sudo apt-get install -y --no-install-recommends intel-oneapi-runtime-opencl
  8. Run test, argument is the platform to use: (note it works on the Azure VM):
    ./test 0
    Platform: Intel(R) OpenCL
    OpenCL: Build log: Compilation started
    Compilation done
    Linking started
    Linking done
    Device build started
    Options used by backend compiler: -cl-std=CL1.2 -w
    Device build done
    Kernel <test> was successfully vectorized (16)
    Done.
On the VMWare VM this has the error:
./test 0
Compilation done
Linking started
Linking done
Device build done
Kernel <test> was successfully vectorized (8)
Done.
Alberto_R_Intel
OCLdev, Thank you for posting in the Intel® Communities Support.
Just to let you know, the thread was already moved to the proper department, they will further assist you with this matter as soon as possible.
Albert R.
