571 Discussions
'Asphalt Legends United' Graphics Discoloration Issues
Risinglion21
I installed Asphalt Legends United game today from 'Steam'. But then I noticed an issue. Whenever I joined a race, a weird discoloration issue will occur. It starts occuring from the second race after game launch. That is, after launching the game, if we join a race, the issue will not occur. But if we join any other race after that, it starts happening.
My Laptop Specs:
CPU: i5-1035G1
GPU: Intel UHD Graphics
Ram: 8gb
I have played the game before, but this didn't happen then. I uninstalled it about 3 months back and installed it now, and this started happening.
Steps I tried:
1. Using the latest driver: 30.0.101.2134 (I was already using the latest driver)
2. Downgrading to older drivers: I tried about 3 older drivers from different times. Nothing solved the issue
3. I already have the latest version of Windows 11( Build 26100.3323) as well as the game.
4. It started as soon as I installed the game.
5. I tried the ' Microsoft Store' version of the game, still the exact same issue.
6. I tried changing the game graphics settings but still no improvements.
5. I have attached a video of the issue along with the graphics settings within the game.(Sorry for the low resolution. I had to compress it to below 23 mb. The texts are still readable).
So, please give me a solution for this problem.
(Virus scan in progress ...)
Earl_Intel
Hi Risinglion21,
Upon checking, the issue is fix on Intel Graphics Driver version: 31.0.101.4672 or newer driver.
Give us an update if there will be changes on the issue.
Earl E.
Risinglion21
As you can see, I am on Intel UHD Graphics, but you gave me the driver for arc and iris xe graphics, which is not supported by my gpu. Is there a fix available for my gpu?
Graphics: Intel UHD Graphics
Processor: Intel Core i5-1035G1
Current driver version: 31.0.101.2134(latest one available as of me writing this)
7adhu_1
i am also experiencing this same issue on my device
pc spec
GPU : Intel(r) UHD Graphics
CPU : i3-1005G1
Risinglion21
It seems like it only happens in this gpu: Intel UHD Graphics G1(denoted by the G1 after the processor name)
Risinglion21
And i don't know what happened but now the glitches start happening from the first race itself.
Earl_Intel
Hello Risinglion21,
Thank you for sharing this update with us.
Apologies for the confusion on the troubleshooting, no worries, I will further investigate on this.
To assist us on the investigation, kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have: Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
7adhu_1
Here is an another scan we both have the same problem so i think it might help to find the error or the problem
Risinglion21
Here's the SSU scan you asked for.
Earl_Intel
Hello Risinglion21,
Thank you for sharing the SSU logs.
I will review the provided logs and will get back to you on this thread with an update as soon as possible.
Hi 7adhu_1,
Thank you for sharing the SSU logs with us, for us to better focus on your concern, kindly create a new thread.
Earl E.
7adhu_1
hi intel me and risinglion has the same issue thats why im also posting my issues here
Earl_Intel
Hi Risinglion21,
I'm still currently investigating the issue that you have while playing Asphalt Legends United.
  • Can you please elaborate with us more about the issue you're experiencing on your system? is it artifacts, graphics glitches, etc.
  • Can you describe to us how the game is encountering discoloration?
Hello 7adhu_1,
I understand that you're having similar issues with Risinglion21, but for us to prioritize and focus on your concern, we recommend you create a new thread.
Earl E.
