I installed Asphalt Legends United game today from 'Steam'. But then I noticed an issue. Whenever I joined a race, a weird discoloration issue will occur. It starts occuring from the second race after game launch. That is, after launching the game, if we join a race, the issue will not occur. But if we join any other race after that, it starts happening.
My Laptop Specs:
CPU: i5-1035G1
GPU: Intel UHD Graphics
Ram: 8gb
I have played the game before, but this didn't happen then. I uninstalled it about 3 months back and installed it now, and this started happening.
Steps I tried:
1. Using the latest driver: 30.0.101.2134 (I was already using the latest driver)
2. Downgrading to older drivers: I tried about 3 older drivers from different times. Nothing solved the issue
3. I already have the latest version of Windows 11( Build 26100.3323) as well as the game.
4. It started as soon as I installed the game.
5. I tried the ' Microsoft Store' version of the game, still the exact same issue.
6. I tried changing the game graphics settings but still no improvements.
5. I have attached a video of the issue along with the graphics settings within the game.(Sorry for the low resolution. I had to compress it to below 23 mb. The texts are still readable).
So, please give me a solution for this problem.
Hi Risinglion21,
Upon checking, the issue is fix on Intel Graphics Driver version: 31.0.101.4672 or newer driver.
Give us an update if there will be changes on the issue.
Earl E.
As you can see, I am on Intel UHD Graphics, but you gave me the driver for arc and iris xe graphics, which is not supported by my gpu. Is there a fix available for my gpu?
Graphics: Intel UHD Graphics
Processor: Intel Core i5-1035G1
Current driver version: 31.0.101.2134(latest one available as of me writing this)
i am also experiencing this same issue on my device
pc spec
GPU : Intel(r) UHD Graphics
CPU : i3-1005G1
It seems like it only happens in this gpu: Intel UHD Graphics G1(denoted by the G1 after the processor name)
And i don't know what happened but now the glitches start happening from the first race itself.
Hello Risinglion21,
Thank you for sharing this update with us.
Apologies for the confusion on the troubleshooting, no worries, I will further investigate on this.
To assist us on the investigation, kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have: Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Here is an another scan we both have the same problem so i think it might help to find the error or the problem
Hello Risinglion21,
Thank you for sharing the SSU logs.
I will review the provided logs and will get back to you on this thread with an update as soon as possible.
Hi 7adhu_1,
Thank you for sharing the SSU logs with us, for us to better focus on your concern, kindly create a new thread.
Earl E.
hi intel me and risinglion has the same issue thats why im also posting my issues here
Hi Risinglion21,
I'm still currently investigating the issue that you have while playing Asphalt Legends United.
- Can you please elaborate with us more about the issue you're experiencing on your system? is it artifacts, graphics glitches, etc.
- Can you describe to us how the game is encountering discoloration?
Hello 7adhu_1,
I understand that you're having similar issues with Risinglion21, but for us to prioritize and focus on your concern, we recommend you create a new thread.
Earl E.
Hello Risinglion21,
Just wondering if you got a chance to look at the questions I posted. In order for me to decide the appropriate course of action to address this issue, kindly inform me as soon as possible.
Earl E.
Hi Risinglion21,
Earl E.
Hey Risinglion21
I finally found a solution for this!!! On steam, launch asphalt with the launch parameters:
--backend vulkan
It seems to have solved the issue for me with this chipset, leading me to believe dx3d12 and the GPU drivers causes this issue.
a guy named halfafk helped me with this one on one of my posts gotta give him the credit it also worked for my i hope it works for you
