702 Discussions
Does Arc control "Opt into Driver boost" setting benefit Iris Xe Graphics?
Xillvion
New Contributor II
Two days ago, I found out that I can install the Arc drivers on Iris Xe, which I had no problems after doing so.
This setting in Arc control called "Opt into Driver boost" is supposed to improve game performance/stability. So i'm wondering if Iris Xe Graphics have the same benefits as Arc GPUs do.
Andres_Intel
Hello Xillvion,
Thank you for posting on the Intel communities.
To provide you with accurate information I will need more time to check if the setting in Intel® Arc™ Control called "Opt into Driver boost" has the same benefits as Intel® Arc™ Graphics for Intel® Iris® Xe Graphics.
Andres P.
Andres_Intel
Hello Xillvion,
I am still investigating your request, for a better understanding, please provide the following information:
  • What is the Intel® Arc™ driver version that you have installed?
Andres P.
Xillvion
New Contributor II
31.0.101.3802, but i'm updating to 31.0.101.3959, only to see if the problems from the beta version still exist.
Andres_Intel
Hello Xillvion,
Thank you for your response.
Now that you provided me with that information, I will be able to continue with the investigation to check if Iris Xe Graphics has the same benefits as Arc GPUs do when "Opt into Driver boost" is enabled.
Andres P.
Andres_Intel
Hello Xillvion,
As per my investigation, enabling "Opt into Driver Boost" will update the drivers with the latest optimizations for games/apps and it will improve the performance/stability. This applies to Intel® Integrated Graphics and Intel® Arc™ Graphics.
As the information you needed was provided, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Andres_Intel
Hello Xillvion,
Andres P.
Andres_Intel
Hello Xillvion,
Andres P.
