701 Discussions
Good PC with better CPU but worse fps,
krzyss19
Hello, sorry for my bad english, im not a native english speaker, so let's get started, recently i bought a new pc with specs below
GPU: Nvidia Geforce Gigabyte RTX 3080 12 GB Gaming OC
CPU: Intel Core i9-11900k
RAM: 1x32gb 3200 mhz
Motherboard: Gigabyte Z590 Gaming X
Disc: Samsung SSD M2
My main question is why do i have way worse fps with better cpu and slightly better GPU than guy in this video     https://youtu.be/Rrc6ntWss0o
I have like 30/40 fps less with same settings in this game, i wonder whats the problem and how can i fix it.  Is my pc damaged, or that guy just overclocked everything to its maximum and thats why there is a huge gap between me and his fps. Pls help me. Best regards Christopher.
AlHill
Update your motherboard bios.  If you do not know how, contact gigabyte.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
