This is what it's look like the graphics glitch, maybe some solution intel? The FPS is stable, but the spider horse is so much worse.
The graphics glitch could be due to outdated or incompatible graphics drivers. Update your Intel graphics drivers to the latest version. If the problem persists, consider adjusting the graphics settings in your game or checking for game-specific patches or updates.
So i tried using the latest driver, and the game wont open at all, and the version of the GoT is the latest
Hi exaudi26,
We will check the issue internally and will need the following details:
- Driver versions that you tried so far.
- System Support Utility (SSU) log. This will help us understand your system's setup. Please see How to get the Intel® System Support Utility Logs on Windows*
- Game's setting
- Minimum Requirements Link:
- Distribution Service (example: Steam / Origin / Epic / XboxGamePass / Ubisoft Connect):
- Graphic Quality (Low, Medium, High, Ultra):
- Resolution (1920x1080, 3840x2160):
- Vsync (On/Off):
- Window Display Configuration (Fullscreen / Windowed/ Borderless Windowed):
Caguicla C.
Hi exaudi26,
Good day!
I'm following up to see if you've had a chance to review our previous message. If so, please confirm and provide the information we request to check this issue.
Caguicla C.
Hi exaudi26,
As we have not heard from you for the past few days, we will go ahead and close this thread. If you need help in the future, please submit a new question as this thread will no longer be monitored.
Caguicla C.
I have the exact same Problem I have been desperately looking for a solution for months. I am currently running this game on 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz 2.42 GHz and I have 24GB of RAM. GPU Intel (R) Iris (R) Xe Graphics
