No Direct 12 Ultimate
PenPusher
Hi, I have an Intel i12700k, 32Gb ram.
While my EVGA3070Ti gets swapped out, I noticed that I have no DirectX 12_2 Ultimate graphics, shows as not being enabled.
I am using Intel Arc graphics driver Ver 31.0.101.3802, Dxdiag shows Ultimate as disabled.
Also Rebar is greyed out and Gpu-z indicates disabled as well! It is enabled on motherboard bios.
Any ideas... Dxdiag txt, Cpu-z, Gpu-z attached
Windows 11 pro Version 10.0.22621 Build 22621
Asus Tuf Gaming Z690 Plus WiFi D4 Bios Ver 2103
32Gb DDR4 3200 Corsair ram.
Jean_Intel
Hello PenPusher,
Thank you for posting on the Intel️® communities. They are sorry to hear that you are experiencing issues with your system.
Regarding your issue, it is important to mention that your processor supports DirectX12.
Remember that DirectX* drivers must be installed separately and are included in Windows* or can be installed via Windows Update. Refer to the following link for more information on How to install the latest version of DirectX*.
Jean O.
Jean_Intel
Hello PenPusher,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello PenPusher,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
