597 Discussions
No puedo configurar la escala de mi pantalla.
Fijnes
Hola, he visto que otras personas pueden configurar la escala de su pantalla asi:
Pero a mi solo me aparecen estas opciones y solo quiero configurar la escala de mi pantalla.
Muchas gracias.
Jose_Intel
Hello @Fijnes
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
I am sorry to hear that you have problems changing the scale, and I’ll be more than happy to help you.
Please download Intel® Graphics Command Center (Beta), you will find the option there.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Jose_Intel
Hello @Fijnes
Jose B.
Fijnes
Gracias me sirvió!!
Jose_Intel
Hello Fijnes
Thank you for letting me know that the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jose B.
