555 Discussions
Tengo un problema con el fc 25 y necesito ayuda
Jereee
Básicamente, lo que me sucede es que inicio el juego tranquilamente, juego un partido y en 2 minutos me da un error y el juego crashea. Este es el error: DirectX function getdeviceremovedreason failed with dxgi_error_device_hung (The GPU will not repond to more commands") GPU: "Intel (R) Xe (R) Graphics" Desde que juego al FIFA 23 me sucede, pero ahora el error me sucede muchísimas veces. Necesito ayuda porque es injugable
Mis Componentes son:
CPU: Intel(R) Core(TM) i3-10100F
RAM 16GB
GPU: Intel (R) Xe (R) Graphics
JeanetteC_Intel
Hello Jereee,
Tenga en cuenta que solo puedo ayudarlo en el idioma inglés. He utilizado una herramienta de traducción web para traducir esta respuesta, por lo tanto, puede haber alguna traducción inexacta. A partir de ahora les responderé en inglés.
I'm sorry to hear that you are unable to play your game (FIFA 23) properly and that you are having DirectX error. Can you confirm that your processor is Intel® Core™ i3-10100F Processor? If this is correct, then you may have to share your system configuration so I can properly check and provide an appropriate fix, since this processor does not have onboard graphics. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). Attach the log file as you reply.
Please also make sure that your system meets the game system requirements so it will run smoothly.
I will wait for your reply.
JeanetteC.
Jereee
Hello, the error occurs in FC 25 and if my processor is Intel Core®™ i3-10100F there I will send my system configuration and I think my PC meets the requirements since I play the game with 60 stable fps but then it crashes.
JeanetteC_Intel
Hello Jereee,
Thank you for sharing the information I requested. I'll further check on this internally and I will post an update once it's available.
JeanetteC.
JeanetteC_Intel
Hello Jereee,
Please be advised that the "F" series processor (Intel Core i3-10100F) does not have an integrated graphics. Upon further checking, it seems that your motherboard has onboard graphics, the reason why you are seeing Intel® Iris® Xe Graphics.
I highly recommend proceeding with a clean installation of the latest OEM driver, version 30.0.100.9864. Once done you may proceed with the troubleshooting steps from the article links below. *These steps are also applicable to FIFA 23.
Let me know how it goes.
JeanetteC.
