UHD 620 800 X 600 not working
ISHPREET1
so i used to play csgo , valorant , dark souls and other games on my uhd 620 with 8gb ddr4 ram. I used to play 800 X 600 resolution for an ideal framerate and graphics ratio. But i had to reset my pc due to virus issues . Now ,800 x 600 resolution is not available in setting or any ingame settings , when i manage to create a custom resolution through cru ,i shows a black screen with audio. Yeah i have the latest drivers . Can someone please help me out?
Hugo_Intel
Hello ISHPREET1
Thank you for posting on the Intel Communities. I am sorry that you are experiencing issues with the resolution settings on your system.
Please try setting a custom resolution through Intel® Graphics Command Center following the instruction in the following article:
How to Set Custom Resolutions and Modes in Intel® Graphics Command Center
If the issue persists, please let us know the following information:
What is the minimum resolution that you set?
If applicable, what is your monitor make and model as well as the type of connections that you are using?
Create a log file with the Intel® System Support Utility and attach it.
Hugo O.
Hugo_Intel
Hello ISHPREET1
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello ISHPREET1
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
