dirt rally 2.0
ceco8
Hello everyone after several crashes on louding race map in dirt rally 2.0. I tried around and found out that setting the graphics texture to very high was causing the crashes for me. Is there already a solution for this problem?
  1. gpu arc a580 driver 5328
  2. cpu i3 10105f
  3. msi b460m a-pro
  4. bequit 550w
  5. Ram 8gb
RyanFeeko
New Contributor II
hi @ceco8 have you check the resources usage while playing? CPU, GPU and RAM usage and temperature.
is it in optimal/standard range?
