21991 Discussions
İntel HD Graphics 5500 Vram Problem
I want to upgrade Vram. No graphics settings on the Bios menu.
Hello YavuzSinan42,
Thank you for contacting the Intel community.
If you are talking about increasing the Virtual memory, this is an option that it needs to be available in your system BIOS, if that option is not available in your system BIOS, then this is a limitation by your system manufacturer.
I'm not sure who your system manufacturer is, since you did not mentioned it but you could try contacting your computer manufacturer for a possible BIOS update to see if this option appears in the BIOS.
You can also check this link:
/thread/85267 https://communities.intel.com/thread/85267
This post explained about dedicated video memory
Ivan.
Hello YavuzSinan42,
Ivan.
