ıntel® 7.-10. nesil işlemci grafikleri - windows* güncelleme yaparken intel 8 hata kodu veriyor. Bilen var mı?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Hi @khakledon0m
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
We understand you have opened an email with us, and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
Carlos L.
