19532 Discussions
Встроенная видео карта Intel UHD Graphics 750
Александр2
операционная система вин 10 pro. Процессор Intel Core i5-11600 OEM
 материнская плата:  GIGABYTE B560M AORUS ELITE
Проблема: Система не видит встроенную VGA , а только дискретную.
Не возможно установить драйвера для нее. При попытке установить драйвера ,система автоматически пытается их установить на дискретную и выдает ошибку ..
Возможно такое ,что система отключает встроенную VGA при подключенной дискретной карте ? И насколько критично отсутствие драйверов для встроенной VGA ?
Возможно ,что из-за этого я не могу установить " Интел RST" ?
JosueO_Intel
Hello Александр2,
Thank you for posting on the Intel®️ communities.
It is important for you to know that our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Regarding your inquiries, in this case, there is a possibility that your system does not support hybrid graphics. This technology allows using both discrete graphics and integrated graphics at the same time, if your system doesn't support hybrid graphics, it means that it will only be using 1 graphics card.
If a discrete graphics card is connected, by default, all graphic demanding operations will be handled by it, this means that the only drivers that you will need are the ones provided by the discrete graphics card manufacturer, and the ones for the Intel one will not be used since it gets disabled.
Not being able to install the drivers for the integrated graphics will not affect the performance since the GPU is disabled and the system is only using the discrete one. In case you have doubts about your system supporting hybrid graphics, please contact your motherboard manufacturer to check with them if the feature is available for your system.
Regarding your inquiry about Intel® RST, this graphics situation should not affect the installation, in case you need assistance with the Intel® Rapid Storage Technology, please create a new thread explaining the situation in order for us to assist you.
Josue O.
JosueO_Intel
Hello Александр2,
Josue O.
