22241 Discussions
Не запускается Intel Graphics Control Panel
TerMos1
Пытался открыть IGX но оно е открывается, обновил драйвер (у меня встроенная видеокарта UHD Graphics 630) на нужный драйвер ,оно успешно обновилась, но IGX таки не запустился((((
помогите пожалуйста!!!!!!!!
David_G_Intel
Hello TerMos1
Thank you for posting on the Intel️® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
For 6th Generation Intel® Core Processors and newer, the Intel Graphics Control Panel has been discontinued and has been replaced with the Intel Graphics Command Center. See How to Install the Intel® Graphics Command Center for installation instructions:
David G
David_G_Intel
David G.
David_G_Intel
David G.
