23269 Discussions
无法自定义分辨率
Idris
我的N卡控制中心和英特尔显卡控制中心都无法自定义分辨率
AndrewG_Intel
Hello @Idris
请注意,我仅能以英语提供支持。我使用了一个 Web 翻译工具来翻译此响应,因此,可能有一些不准确的翻译
We understand that you have an inquiry or issue regarding custom resolution. Is this correct? Could you please elaborate more regarding what you are trying to achieve and/or any issue that you are experiencing?
Also, please run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach it to your reply.
  • To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
AndrewG_Intel
Hello Idris
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
AndrewG_Intel
Hello Idris
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
