笔记本电脑连接外接显示器时,选择仅在外接显示器显示时(仅第二屏幕),无法调节分辨率。
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
thank you!
i had a try. but i finally failed to submit.
You didn't follow the instructions. Read them again, this time all the way to the end.
Regardless, I can answer this. It is not a problem with the graphics engine or with the graphics driver installed. There are many low-end laptops that artificially limit the resolutions (etc.) of external displays to that of the embedded display. It's a restriction that they put in place to push people to purchase their more-expensive laptop models. Unfortunately, I don't know of any good solution for this problem (fat chance of getting the vendors to stop this practice; it's greed, pure and simple).
thanks.
I post replied with the text
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"08/21/2024"
Time:"00:00:24.4516235"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"XIAOMI"
BIOS Mode:"UEFI"
BIOS Version/Date:"XIAOMI RMARP4B0P0505 , 03/21/2024 12:00 上午"
CD or DVD:"Not Available"
Embedded Controller Version:"1.5"
Platform Role:"Mobile"
Processor:"13th Gen Intel(R) Core(TM) i7-13620H , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.4"
Sound Card:"适用于数字麦克风的英特尔® 智音技术"
Sound Card:"USB Audio Device"
Sound Card:"Realtek High Definition Audio"
Sound Card:"适用于蓝牙® 音频的英特尔® 智音技术"
Sound Card:"适用于 USB 音频的英特尔® 智音技术"
System Manufacturer:"XIAOMI"
System Model:"Redmi Book 14 2024"
System SKU:"TM2301-57659"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) UHD Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"0.13 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) UHD Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=UHD+Graphics"
CoInstallers:"oem5.inf,iRPLPD_w10_DS,Internal,Intel(R) UHD Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdn64.sys"
Driver Date:"02/21/2024 08:00 上午"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_1baad0041739883d\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.5333"
INF:"oem5.inf"
INF Section:"iRPLPD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"<>,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_1baad0041739883d\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_1baad0041739883d\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_1baad0041739883d\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_A7A8&SUBSYS_23011D72&REV_04\3&11583659&1&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"120 Hz"
Refresh Rate - Maximum:"0 Hz"
Refresh Rate - Minimum:"Not Available"
Resolution:"2880 X 1800"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) UHD Graphics Family"
- "OrayIddDriver Device"
Adapter Compatibility:"Shanghai Best Oray Information Technology Co., Ltd."
Adapter DAC Type:"Not Available"
Adapter RAM:"Not Available"
Availability:"Offline"
Bits Per Pixel:"Not Available"
Caption:"OrayIddDriver Device"
CoInstallers:"oem67.inf,OrayIddDriver_Install.NT,Not Available,Not Available"
Color Table Entries:"Not Available"
Driver:"WUDFRd.sys"
Driver Date:"11/15/2022 08:00 上午"
Driver Path:"C:\Windows\system32\drivers\WUDFRd.sys"
Driver Provider:"Shanghai Best Oray Information Technology Co., Ltd."
Driver Version:"17.1.58.818"
INF:"oem67.inf"
INF Section:"OrayIddDriver_Install.NT"
Installed Drivers:"Not Available"
Manufacturer:"Shanghai Best Oray Information Technology Co., Ltd."
Monochrome:"No"
Number of Colors:"Not Available"
PNP Device ID:"ROOT\DISPLAY\0000"
Refresh Rate - Current:"Not Available"
Refresh Rate - Maximum:"Not Available"
Resolution:"Not Available"
Scan Mode:"Not Available"
Service Name:"WUDFRd"
Status:"OK"
Video Processor:"Not Available"
- "Memory"
Physical Memory (Available):"5.53 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15.73 GB"
- "BANK 0"
Capacity:"2 GB"
Channel:"Controller0-ChannelA"
Configured Clock Speed:"5200 MHz"
Configured Voltage:"500 millivolts"
Data Width:"16 bits"
Form Factor:"Unknown"
Interleave Position:"First position"
Manufacturer:"SK Hynix"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"H58G66AK6HX079"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"2 GB"
Channel:"Controller1-ChannelA"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Channel:"Controller0-ChannelB"
Interleave Position:"Second position"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Channel:"Controller1-ChannelB"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Channel:"Controller0-ChannelC"
Interleave Position:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Channel:"Controller1-ChannelC"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Channel:"Controller0-ChannelD"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Channel:"Controller1-ChannelD"
Type:"Synchronous"
- "Motherboard"
BIOS:"RMARP4B0P0505, XMCC - 2"
Caption:"主板"
Chipset:"Not Available"
Date:"03/21/2024 08:00 上午"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"TM2301"
Serial Number:"5210M59SMP000454P0187"
Status:"OK"
Version:"V24B2"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.22621.2506"
Index:"0002"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"08/20/2024 10:14 下午"
MAC Address:"10:91:D1:AE:FE:3D"
Manufacturer:"Microsoft"
Net Connection ID:"蓝牙网络连接"
NetCfgInstanceId:"{F334D9A9-2ACD-4376-9350-40D4BB13EC05}"
PNP Device ID:"BTH\MS_BTHPAN\6&1F19680F&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"以太网 802.3"
- "Service Bindings"
Internet 协议版本 4 (TCP/IPv4):
Internet 协议版本 6 (TCP/IPv6):
Microsoft LLDP 协议驱动程序:
Microsoft 网络的文件和打印机共享:
Microsoft 网络客户端:
链路层拓扑发现响应程序:
链路层拓扑发现映射器 I/O 驱动程序:
- "Intel(R) Wi-Fi 6 AX203"
Access Point:"8c:53:c3:d8:ff:a2"
Authentication:
- "Caption":"Intel(R) Wi-Fi 6 AX203"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6+AX203"
Channel:
Cipher:
Connection Mode:
Default IP Gateway:"192.168.31.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"08/22/2024 09:50 上午"
DHCP Lease Obtained:"08/21/2024 09:50 下午"
DHCP Server:"192.168.31.1"
Driver:"Netwtw12.sys"
Driver Date:"07/26/2023 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\Netwtw12.sys"
Driver Provider:"Intel"
Driver Version:"22.250.0.4"
Index:"0003"
INF:"oem51.inf"
INF Section:"Install_GEN_SLR_JnP_203_AX_no_160_2x2_WinT_non_6e"
Installed:"Yes"
IP Address:"192.168.31.182;fe80::60ac:9ee5:9b58:e421"
IP Subnet:"255.255.255.0;64"
MAC Address:"10:91:D1:AE:FE:39"
Net Connection ID:"WLAN"
NetCfgInstanceId:"{C68361D0-8218-44CC-938F-A1F2487F1744}"
Network Name:"灏忓垎闃焈5G"
Network Type:
PNP Device ID:"PCI\VEN_8086&DEV_51F1&SUBSYS_02748086&REV_01\3&11583659&1&A3"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Wi-Fi 6 AX203"
Profile:
Radio Type:
Receive Rate:
Service Name:"Netwtw12"
Signal Strength:
State:
Status:"Enabled"
Transmit Rate:
Type:"以太网 802.3"
Microsoft 网络客户端:
QoS 数据包计划程序:
链路层拓扑发现响应程序:
- "Settings"
*DeviceSleepOnDisconnect:WoWLAN 断开连接时睡眠:"已禁用 (0)"
*PacketCoalescing:数据包合并:"已启用 (1)"
*PMARPOffload:WoWLAN 的 ARP 卸载:"已启用 (1)"
*PMNSOffload:WoWLAN 的 NS 卸载:"已启用 (1)"
*PMWiFiRekeyOffload:WoWLAN 的 GTK 重新生成密钥:"已启用 (1)"
*WakeOnMagicPacket:唤醒幻数据包:"已启用 (1)"
*WakeOnPattern:唤醒模式匹配:"已启用 (1)"
ChannelWidth24:2.4GHz 信道宽度:"自动 (1)"
ChannelWidth52:5GHz 信道宽度:"自动 (1)"
CtsToItself:混合模式保护:"RTS/CTS 已启用 (0)"
FatChannelIntolerant:与 40Mhz 信道不兼容:"已禁用 (0)"
IbssTxPower:传输电源:"5. 最高值 (100)"
IEEE11nMode:802.11n/ac/ax 无线模式:"4. 802.11ax (3)"
MIMOPowerSaveMode:MIMO 节能模式:"自动 SMPS (0)"
RoamAggressiveness:漫游主动性:"3. 中间 (2)"
RoamingPreferredBandType:首选频带:"1. 无首选项 (0)"
ThroughputBoosterEnabled:吞吐量助推器:"已禁用 (0)"
uAPSDSupport:支持 U-APSD :"已禁用 (0)"
WirelessMode:802.11a/b/g 无线模式:"6. 双频带 802.11a/b/g (34)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Internet Explorer,11.1, Microsoft Edge,127.0"
Locale:"中华人民共和国"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 家庭中文版"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"2.88 GB"
Physical Memory (Available):"5.55 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.22631 Build 22631"
Virtual Memory (Available):"4.86 GB"
Virtual Memory (Total):"18.61 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5027397:"Update [8/19/2024]"
KB5039338:"Update [8/19/2024]"
KB5041584:"Security Update [8/19/2024]"
KB5041585:"Security Update [8/19/2024]"
KB5041655:"Update [8/19/2024]"
KB5042099:"Update [8/19/2024]"
- "Processor"
- "13th Gen Intel(R) Core(TM) i7-13620H"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 186 Stepping 2"
- "Chipset Name":"13th Gen Intel(R) Core(TM) i7-13620H"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=13th+Gen++Core+i7+13620H"
CPU Speed:"2.40 GHz"
Current Voltage:"9. volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.22621.3672"
Ext. Family:"Not Available"
Family:"Intel Core™ i7-2760QM"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"10 x 288 KB"
Level 2 Cache:"10 x 9728 KB"
Level 3 Cache:"24 MB"
Load:"3%"
Manufacturer:"GenuineIntel"
Model:"186"
Name:"13th Gen Intel(R) Core(TM) i7-13620H"
Number of Cores:"10"
Number of Cores Enabled:"10"
Number of Logical Processors:"16"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000B06A2"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"2"
- "Storage"
- "FORESEE XP2000F001T"
Capablities:"Random Access, Supports Writing"
Caption:"FORESEE XP2000F001T"
Cylinder - Total:"124519"
Description:"磁盘驱动器"
Error Code:"Device is working properly"
Firmware Revision:"V1223G0T"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(标准磁盘驱动器)"
Model:"FORESEE XP2000F001T"
Partitions:"4"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_FORESEE_XP2000F0\5&42E240F&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Per Track:"63"
Sectors - Total:"2000397735"
Serial Number:"0000_0007_2401_1011_3A5A_2704_0400_0ACE."
Size – Available:"884.39 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"31752345"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"本地固定磁盘"
File System:"NTFS"
Serial Number:"48B9DB1D"
Size – Available:"137.25 GB"
Volume Dirty:"No"
- "D:"
Caption:"D:"
File System:"NTFS"
Serial Number:"A2BA329D"
Size – Available:"747.14 GB"
Volume Dirty:"No"
...#SSU#...
Hi 会炒菜的电饭锅,
Thank you for posting in Intel Communities and for posting the results of the Intel System Support Utility.
Since you are having issues adjusting the resolution, please try the following:
1. Just to confirm, when you are on extended mode, that is the only time you can adjust the resolution of the external monitor, am I correct?
When on display to external monitor only, that is where you have problems adjusting the resolution, am I right?
2. How is the external monitor connected to your system? Via HDMI, Display Port, etc.?
3. You are using an older version of the graphics driver which you may have downloaded from your laptop’s support page. Most of the time that driver is the best for your system; however, since you are experiencing issues with it, please try to install our latest generic driver, 32.0.101.5972.
4. Do you have either Intel ARC Control or Intel Graphics Command Center installed?
Alfred S
Hi Alfred S,
Thank you for your reply.
1. You are right. When on display to external monitor only, that is where I have problems adjusting the resolution.
2. The external monitor connect to my system Via thunderbolt.
Just now, I also had a try to connect to my system via HDMI, it still did'nt work.
3. I installed your latest generic driver, 32.0.101.5972. But, it's still the same as previous stiuation.
4. Yes, I have Intel ARC Control.
Plesase check it again taking the screenshots as the refference.
会炒菜的电饭锅
Hi 会炒菜的电饭锅,
Thank you for your response.
Kindly try the suggestions listed on this page, Unable to Select the Native Resolution and Other Supported Refresh Rate of an External Display Connected to Intel® Graphics.
Please let us know of the results.
Alfred S
Hi 会炒菜的电饭锅
We are just following up.
It looks like you need more time to carry out the recommendations that we have provided.
Alfred S
你好,尝试了您的解决方案,结果还是不行。
我用其他的电脑连接显示器是可以的。
I believe that the problem here is within the laptop itself. Many laptops improperly prevent external monitors from using resolutions that are above that of the internal display. To test for this possibility, while using the external monitor, disable the internal display and see if you can then change the resolution. Try this first by (a) shutdown (if not already), (b) press power button to start power on, (c) close the lid of the laptop, and (d) wait for signon via external monitor. If that doesn't work, try using Control Panel to disable the internal display and then reboot.
If via either method, you are able to make the adjustment in the resolution, then you know it'd the laptop's fault and you need to contact the laptop vendor for next-steps (if they will even entertain such).
Hope this helps,
Thank you.
Via this method, I 'm able to make the adjustment in the resolution.
Hi 会炒菜的电饭锅,
Kindly check the suggestion of one of our super users.
Thank you for the insightful recommendation @n_scott_pearson
Please let me know of the results.
Alfred S
Hi 会炒菜的电饭锅,
It looks like you need more time to carry out the recommendations that one of our community users provided.
Alfred S
Thank you.
Via the the insightful recommendation @n_scott_pearson, I 'm able to make the adjustment in the resolution.
...And keep this adjustment while reenabling the internal display?
合上笔记本电脑的盖子,只连接外部显示器是可以的。
Thank you for your update.
We are glad to know that your issue is already resolved. Much obliged @n_scott_pearson
If you would like to give us an update or if you have further questions, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great year.
Alfred S
