我使用Intel® Driver & Support Assistant更新了我的i7-11800H处理器所拥有的集成显卡,并在更新完成后进行了一次系统重启,但我的笔记本电脑却进入了黑屏状态(开机时的Windows徽标及安全模式均可正常使用)。随后,我进入了系统BIOS界面并更改为了独显模式,这解决了我的问题,使计算机可以正常启动,但我发现我的独显无法识别了(包括Windows设备管理器和Intel® Driver & Support Assistant软件),直接运行驱动安装程序也无法进行,请问此问题该1如何解决? 附:计算机部分信息 Microsoft Windows 10 专业版 CPU:Intel i7-11800H GPU:集成显卡 NVDIA GeForce 3060 Laptop 望早日回复 祝:生活愉快 I used Intel ® Driver & Support Assistant to update the integrated graphics card on my i7-11800H processor, and after the update was completed, I did a system reboot, but my laptop went black (the Windows logo and safe mode work normally when booting). Then, I went to the system BIOS interface and changed to the unique display mode, which solved my problem and allowed the computer to start normally, but I found that my unique display was not recognized (including Windows Facility Management and Intel ® Driver & Support Assistant software), and I couldn't run the driver installer directly. How to solve this problem? Attachment: Computer part information Microsoft Windows 10 Professional CPU: Intel i7-11800H GPU: Integrated graphics card NVDIA GeForce 3060 Laptop Hope to reply soon. Have a nice day.
Completely uninstall the existing driver, boot windows safe-mode, use DDU software to uninstall the driver, restart windows normally.
You could download the driver manually Intel® Graphics Driver 32.0.101.5768 (WHQL Certified)
and install normally. if you installation fails, extract the executable file with Winrar, then run Installer.exe
If this also gets failure means, using device manager and using inf file install driver
