20621 Discussions
1165G7 cannot play Gameloft Sniper Fury
rdsmokie
Hi the above in a Dell laptop plays the game for like 4 mins and then closes the game down. I have tried all the available Dell and Intel drivers, factory reset laptop and game in in low everything. It does the same with microsoft solitaire suite. Is there a known bug with the Iris XE chips? Has anyone else had this issue with games?? I have been in touch with Dell and they say all hardware seems to be working fine.
   I just downloaded the Intel CPU tester and I have 1 failure on the CPU Frequency
--- IPDT64 - Revision: 4.1.5.37
--- IPDT64 - Start Time: 28/07/2021 08:56:02
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Pass.
CPU 1 - GPUStressW - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPUFreq - Fail.
IPDT64 Failed
--- IPDT64 - End Time: 28/07/2021 08:59:57
FAIL
DeividA_Intel
Hello rdsmokie,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Provide a full report from the Intel® Processor Diagnostic Tool.
- https://downloadcenter.intel.com/download/19792
3. Do you have the same issue with other games? If so, what are the name of the games?
4. Have you tried with driver version 30.0.100.9684?
- https://downloadcenter.intel.com/download/30579/Intel-Graphics-Windows-DCH-Drivers
5. Is this issue recent? If so, when did it start?
Deivid A.
DeividA_Intel
Hello rdsmokie,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello rdsmokie,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
I recommend you check further with the laptop manufacturer and/or the game developer for instructions and requirements for the game.
Deivid A.
