21676 Discussions
11th Gen Intel® Core™ i5-1135G7 × 8 Unable to set 3440*1440 resolution on Ubuntu
DrRobert
Hello sugars!
I'm having a bit of a problem here!
I've switched from Windows to Linux ( currently running Ubuntu 23.10 ) and i can't seem to be able to set the proper resolution to the external monitor :V
Here are my specs:
Model: Dell Inc. Vostro 3400
CPU: 11th Gen Intel® Core™ i5-1135G7 @ 2.40GHz × 8
GPU: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics]
Monitor: HUAWEI MateView GT 34'' Ultrawide Curved Gaming Monitor, 165Hz, 21:9 WQHD
Just to make things clear un Windows it worked just fine, same cable same port!!
Here's an xrandr log:
xrandr --verbose
Screen 0: minimum 320 x 200, current 6912 x 2160, maximum 16384 x 16384
eDP-1 connected 3072x1728+3840+0 (0x45) normal (normal left inverted right x axis y axis) 309mm x 174mm
    Identifier: 0x42
    Timestamp:  121361
    Subpixel:   unknown
    Gamma:      0.53:1.0:1.7
    Brightness: 0.72
    Clones:
    CRTC:       1
    CRTCs:      1 0 2 3
    Transform:  1.599991 0.000000 0.000000
                0.000000 1.599991 0.000000
                0.000000 0.000000 1.000000
               filter: bilinear
    _MUTTER_PRESENTATION_OUTPUT: 0
    EDID:
        00ffffffffffff0038702b0000000000
        011c0104951f117802b370985d598e28
        1c505400000001010101010101010101
        0101010101011a3680a070381f403020
        350035ae1000001a522b80a070381f40
        3020350035ae1000001a000000fe0056
        5030383880313430324c303100000000
        0000412196001000000a010a20200007
    vrr_capable: 0
        range: (0, 1)
    Colorspace: Default
        supported: Default, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, RGB_WIDE_FIXED, RGB_WIDE_FLOAT, BT601_YCC
    max bpc: 12
        range: (6, 12)
    Broadcast RGB: Automatic
        supported: Automatic, Full, Limited 16:235
    panel orientation: Normal
        supported: Normal, Upside Down, Left Side Up, Right Side Up
    scaling mode: Full aspect
        supported: Full, Center, Full aspect
    link-status: Good
        supported: Good, Bad
    CONNECTOR_ID: 308
        supported: 308
    non-desktop: 0
        range: (0, 1)
  1920x1080 (0x45) 138.500MHz +HSync -VSync *current +preferred
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  66.59KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  59.93Hz
  1920x1080 (0x46) 110.900MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  53.32KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  47.99Hz
  1680x1050 (0x47) 119.100MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.73KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.93Hz
  1400x1050 (0x48) 121.915MHz +HSync +VSync
        h: width  1400 start 1488 end 1640 total 1880 skew    0 clock  64.85KHz
        v: height 1050 start 1052 end 1064 total 1082           clock  59.93Hz
  1600x900 (0x49) 97.677MHz +HSync -VSync
        h: width  1600 start 1648 end 1680 total 1760 skew    0 clock  55.50KHz
        v: height  900 start  903 end  908 total  926           clock  59.93Hz
  1280x1024 (0x4a) 107.845MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.89KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  59.93Hz
  1400x900 (0x4b) 86.578MHz +HSync -VSync
        h: width  1400 start 1448 end 1480 total 1560 skew    0 clock  55.50KHz
        v: height  900 start  903 end  913 total  926           clock  59.93Hz
  1280x960 (0x4c) 107.880MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  59.93KHz
        v: height  960 start  961 end  964 total 1000           clock  59.93Hz
  1440x810 (0x4d) 151.771MHz +HSync -VSync DoubleScan
        h: width  1440 start 1464 end 1480 total 1520 skew    0 clock  99.85KHz
        v: height  810 start  811 end  814 total  833           clock  59.93Hz
  1368x768 (0x4e) 72.347MHz +HSync -VSync
        h: width  1368 start 1416 end 1448 total 1528 skew    0 clock  47.35KHz
        v: height  768 start  771 end  781 total  790           clock  59.93Hz
  1280x800 (0x4f) 71.028MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  49.33KHz
        v: height  800 start  803 end  809 total  823           clock  59.93Hz
  1280x720 (0x50) 63.951MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  44.41KHz
        v: height  720 start  723 end  728 total  741           clock  59.93Hz
  1024x768 (0x51) 64.924MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.31KHz
        v: height  768 start  771 end  777 total  806           clock  59.93Hz
  960x720 (0x52) 116.871MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1128 total 1300 skew    0 clock  89.90KHz
        v: height  720 start  720 end  722 total  750           clock  59.93Hz
  928x696 (0x53) 108.937MHz -HSync +VSync DoubleScan
        h: width   928 start  976 end 1088 total 1264 skew    0 clock  86.18KHz
        v: height  696 start  696 end  698 total  719           clock  59.93Hz
  896x672 (0x54) 102.262MHz -HSync +VSync DoubleScan
        h: width   896 start  960 end 1060 total 1224 skew    0 clock  83.55KHz
        v: height  672 start  672 end  674 total  697           clock  59.93Hz
  1024x576 (0x55) 42.080MHz +HSync -VSync
        h: width  1024 start 1072 end 1104 total 1184 skew    0 clock  35.54KHz
        v: height  576 start  579 end  584 total  593           clock  59.93Hz
  960x600 (0x56) 76.916MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  73.96KHz
        v: height  600 start  601 end  604 total  617           clock  59.93Hz
  960x540 (0x57) 37.322MHz +HSync -VSync
        h: width   960 start 1008 end 1040 total 1120 skew    0 clock  33.32KHz
        v: height  540 start  543 end  548 total  556           clock  59.93Hz
  800x600 (0x58) 38.357MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  37.46KHz
        v: height  600 start  601 end  603 total  625           clock  59.93Hz
  840x525 (0x59) 59.550MHz +HSync -VSync DoubleScan
        h: width   840 start  864 end  880 total  920 skew    0 clock  64.73KHz
        v: height  525 start  526 end  529 total  540           clock  59.93Hz
  864x486 (0x5a) 30.686MHz +HSync -VSync
        h: width   864 start  912 end  944 total 1024 skew    0 clock  29.97KHz
        v: height  486 start  489 end  494 total  500           clock  59.93Hz
  700x525 (0x5b) 60.957MHz +HSync +VSync DoubleScan
        h: width   700 start  744 end  820 total  940 skew    0 clock  64.85KHz
        v: height  525 start  526 end  532 total  541           clock  59.93Hz
  800x450 (0x5c) 48.838MHz +HSync -VSync DoubleScan
        h: width   800 start  824 end  840 total  880 skew    0 clock  55.50KHz
        v: height  450 start  451 end  454 total  463           clock  59.93Hz
  640x512 (0x5d) 53.922MHz +HSync +VSync DoubleScan
        h: width   640 start  664 end  720 total  844 skew    0 clock  63.89KHz
        v: height  512 start  512 end  514 total  533           clock  59.93Hz
  700x450 (0x5e) 43.289MHz +HSync -VSync DoubleScan
        h: width   700 start  724 end  740 total  780 skew    0 clock  55.50KHz
        v: height  450 start  451 end  456 total  463           clock  59.93Hz
  640x480 (0x5f) 25.172MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.46KHz
        v: height  480 start  490 end  492 total  525           clock  59.93Hz
  720x405 (0x60) 22.098MHz +HSync -VSync
        h: width   720 start  768 end  800 total  880 skew    0 clock  25.11KHz
        v: height  405 start  408 end  413 total  419           clock  59.93Hz
  684x384 (0x61) 36.173MHz +HSync -VSync DoubleScan
        h: width   684 start  708 end  724 total  764 skew    0 clock  47.35KHz
        v: height  384 start  385 end  390 total  395           clock  59.93Hz
  640x360 (0x62) 17.932MHz +HSync -VSync
        h: width   640 start  688 end  720 total  800 skew    0 clock  22.41KHz
        v: height  360 start  363 end  368 total  374           clock  59.93Hz
  512x384 (0x63) 32.462MHz -HSync -VSync DoubleScan
        h: width   512 start  524 end  592 total  672 skew    0 clock  48.31KHz
        v: height  384 start  385 end  388 total  403           clock  59.93Hz
  512x288 (0x64) 21.004MHz +HSync -VSync DoubleScan
        h: width   512 start  536 end  552 total  592 skew    0 clock  35.48KHz
        v: height  288 start  289 end  292 total  296           clock  59.93Hz
  480x270 (0x65) 18.661MHz +HSync -VSync DoubleScan
        h: width   480 start  504 end  520 total  560 skew    0 clock  33.32KHz
        v: height  270 start  271 end  274 total  278           clock  59.93Hz
  400x300 (0x66) 19.148MHz +HSync +VSync DoubleScan
        h: width   400 start  412 end  448 total  512 skew    0 clock  37.40KHz
        v: height  300 start  300 end  301 total  312           clock  59.93Hz
  432x243 (0x67) 15.343MHz +HSync -VSync DoubleScan
        h: width   432 start  456 end  472 total  512 skew    0 clock  29.97KHz
        v: height  243 start  244 end  247 total  250           clock  59.93Hz
  320x240 (0x68) 12.562MHz -HSync -VSync DoubleScan
        h: width   320 start  328 end  376 total  400 skew    0 clock  31.41KHz
        v: height  240 start  245 end  246 total  262           clock  59.93Hz
  360x202 (0x69) 11.023MHz +HSync -VSync DoubleScan
        h: width   360 start  384 end  400 total  440 skew    0 clock  25.05KHz
        v: height  202 start  204 end  206 total  209           clock  59.93Hz
  320x180 (0x6a)  8.966MHz +HSync -VSync DoubleScan
        h: width   320 start  344 end  360 total  400 skew    0 clock  22.41KHz
        v: height  180 start  181 end  184 total  187           clock  59.93Hz
HDMI-1 connected primary 3840x2160+0+0 (0x6b) normal (normal left inverted right x axis y axis) 797mm x 334mm
    Identifier: 0x43
    Timestamp:  121361
    Subpixel:   unknown
    Gamma:      0.53:1.0:1.7
    Brightness: 0.72
    Clones:
    CRTC:       0
    CRTCs:      1 0 2 3
    Transform:  2.000000 0.000000 0.000000
                0.000000 2.000000 0.000000
               filter: bilinear
    EDID:
        00ffffffffffff0022f6256a22f680c0
        08200103805021780a54b1ac5047a426
        115054bfcf0081408180714f81c0b300
        d1c0010101014ed470a0d0a046503040
        3a001d4e3100001ce77c70a0d0a02950
        30203a001d4e3100001a000000fd0030
        901ea03c010a202020202020000000fc
        005a51452d4341410a202020202001c7
        020348f14b1f9014010304121305025a
        2309070783010000e200d567030c0010
        00384067d85dc4017880006d1a000002
        013090e60000000000e305c081e30f00
        00e606050166661c565e00a0a0a02950
        302035001d4e3100001a9d6770a0d0a0
        225030203a001d4e3100001a464714a0
        a0381f40302018041d4e3100001a001d
    HDCP Content Type: HDCP Type0
        supported: HDCP Type0, HDCP Type1
    Content Protection: Undesired
        supported: Undesired, Desired, Enabled
    max bpc: 12
        range: (8, 12)
    content type: No Data
        supported: No Data, Graphics, Photo, Cinema, Game
    Colorspace: Default
        supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
    aspect ratio: Automatic
        supported: Automatic, 4:3, 16:9
    audio: auto
        supported: force-dvi, off, auto, on
    link-status: Good
    CONNECTOR_ID: 317
        supported: 317
    non-desktop: 0
        range: (0, 1)
  1920x1080 (0x6b) 148.500MHz -HSync -VSync *current
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1920x1080 (0x6c) 148.500MHz +HSync +VSync
  1920x1080 (0x6d) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1920x1080 (0x6e) 148.352MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.43KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  59.94Hz
  1680x1050 (0x6f) 119.000MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.67KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.88Hz
  1280x1024 (0x70) 135.000MHz +HSync +VSync
        h: width  1280 start 1296 end 1440 total 1688 skew    0 clock  79.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  75.02Hz
  1280x1024 (0x71) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1280x960 (0x72) 108.000MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  60.00KHz
        v: height  960 start  961 end  964 total 1000           clock  60.00Hz
  1152x864 (0x73) 108.000MHz +HSync +VSync
        h: width  1152 start 1216 end 1344 total 1600 skew    0 clock  67.50KHz
        v: height  864 start  865 end  868 total  900           clock  75.00Hz
  1280x720 (0x74) 74.250MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  45.00KHz
        v: height  720 start  725 end  730 total  750           clock  60.00Hz
  1280x720 (0x75) 74.250MHz +HSync +VSync
        h: width  1280 start 1720 end 1760 total 1980 skew    0 clock  37.50KHz
        v: height  720 start  725 end  730 total  750           clock  50.00Hz
  1280x720 (0x76) 74.176MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  44.96KHz
        v: height  720 start  725 end  730 total  750           clock  59.94Hz
  1024x768 (0x77) 78.750MHz +HSync +VSync
        h: width  1024 start 1040 end 1136 total 1312 skew    0 clock  60.02KHz
        v: height  768 start  769 end  772 total  800           clock  75.03Hz
  1024x768 (0x78) 75.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1328 skew    0 clock  56.48KHz
        v: height  768 start  771 end  777 total  806           clock  70.07Hz
  1024x768 (0x79) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x7a) 50.000MHz +HSync +VSync
        h: width   800 start  856 end  976 total 1040 skew    0 clock  48.08KHz
        v: height  600 start  637 end  643 total  666           clock  72.19Hz
  800x600 (0x7b) 49.500MHz +HSync +VSync
        h: width   800 start  816 end  896 total 1056 skew    0 clock  46.88KHz
        v: height  600 start  601 end  604 total  625           clock  75.00Hz
  800x600 (0x7c) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x7d) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  720x576 (0x7e) 27.000MHz -HSync -VSync
        h: width   720 start  732 end  796 total  864 skew    0 clock  31.25KHz
        v: height  576 start  581 end  586 total  625           clock  50.00Hz
  720x480 (0x7f) 27.027MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.50KHz
        v: height  480 start  489 end  495 total  525           clock  60.00Hz
  720x480 (0x80) 27.000MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.47KHz
        v: height  480 start  489 end  495 total  525           clock  59.94Hz
  640x480 (0x81) 31.500MHz -HSync -VSync
        h: width   640 start  656 end  720 total  840 skew    0 clock  37.50KHz
        v: height  480 start  481 end  484 total  500           clock  75.00Hz
  640x480 (0x82) 31.500MHz -HSync -VSync
        h: width   640 start  664 end  704 total  832 skew    0 clock  37.86KHz
        v: height  480 start  489 end  492 total  520           clock  72.81Hz
  640x480 (0x83) 30.240MHz -HSync -VSync
        h: width   640 start  704 end  768 total  864 skew    0 clock  35.00KHz
        v: height  480 start  483 end  486 total  525           clock  66.67Hz
  640x480 (0x84) 25.200MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.50KHz
        v: height  480 start  490 end  492 total  525           clock  60.00Hz
  640x480 (0x85) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  720x400 (0x86) 28.320MHz -HSync +VSync
        h: width   720 start  738 end  846 total  900 skew    0 clock  31.47KHz
        v: height  400 start  412 end  414 total  449           clock  70.08Hz
I then tried to manually set it but i get this error:
robert@robert-Vostro-3400:~$ cvt -r 3440 1440 60
# 3440x1440 59.97 Hz (CVT) hsync: 88.82 kHz; pclk: 319.75 MHz
Modeline "3440x1440R"  319.75  3440 3488 3520 3600  1440 1443 1453 1481 +hsync -vsync
robert@robert-Vostro-3400:~$ xrandr --newmode "mymode"  319.75  3440 3488 3520 3600  1440 1443 1453 1481 +hsync -vsync
xrandr --addmode HDMI-1 "mymode"
robert@robert-Vostro-3400:~$ xrandr --output HDMI-1 --mode "mymode" --verbose
screen 0: 6912x2880 1625x677 mm 108.00dpi
crtc 0:       mymode  59.97 +0+0 "HDMI-1"
xrandr: Configure crtc 0 failed
crtc 0: disable
crtc 1: disable
crtc 2: disable
crtc 3: disable
screen 0: revert
crtc 0: revert
crtc 1: revert
crtc 2: revert
crtc 3: revert
If i look at the journalctl logs however it seems that it detects these resolutions ( yes i tried to add one of thise but no success there either )
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Printing DDC gathered Modelines:
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "3440x1440"x0.0  543.50  3440 3488 3552 3600  1440 1443 1453 1510 -hsync +vsync (151.0 >
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "3440x1440"x0.0  319.75  3440 3488 3520 3600  1440 1443 1453 1481 +hsync -vsync (88.8 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "3440x1440"x0.0  265.25  3440 3488 3520 3600  1440 1443 1453 1474 +hsync -vsync (73.7 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "2580x1080"x0.0  182.46  2580 2628 2660 2740  1080 1097 1105 1111 +hsync -vsync (66.6 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vs>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vs>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (--) modeset(0): HDMI max TMDS frequency 320000KHz
Jocelyn_Intel
Hello, @DrRobert
Thank you for posting on the Intel® communities.
I understand that you are having issues with the resolution 3440x1440, I will do my best to assist you here.
  1. How is the monitor connected to the laptop?
  2. Are you using adapters/splitters/docking stations or is it a straight connection (HDMI to HDMI, no adapters)?
  3. Does this happen with another monitor?
  4. Please provide the EDID using the operating system or a third-party tool.
  5. Please attach an Intel SSU report so we can have more information about your system:
Intel® System Support Utility for the Linux* Operating System
Jocelyn M.
Jocelyn_Intel
Hello, @DrRobert
In addition to the previous post, please try the steps recommended in this forum thread: How do I set a custom resolution
Please let me know the results or confirm if you already performed them.
Jocelyn M.
Jocelyn_Intel
Hello, @DrRobert
I hope you are great.
I am checking this thread and I would like to know if you were able to check my previous post.
Jocelyn M.
DrRobert
Hi man! Sorry i was unable to reply in the last couple of days.
I made some progress though it apparently seem to be working now but only if i set a refresh rate of 25 if i set higher than 25 it doesn't work anymore :V
It's connected HDMI to HDMI no adapters or anything, same cable, same port as i had on Windows
  1. Does this happen with another monitor?
Yes i have another 4k monitor ( resolution that should be supported by the integrated GPU but it still can't go beyond 25Hz
I've attatched an SSU report.....since it's working with 25Hz i assume it's a driver issue since with the same setup it was working on WIndows just fine on 60Hz
Jocelyn_Intel
Hello, @DrRobert
Thank you for your reply.
  1. Can you please confirm if you tried the steps recommended in this forum thread: How do I set a custom resolution?
  2. Also, have you installed the driver from your Linux Distribution? The graphics drivers for Linux operating systems are provided by them. I am unable to see the driver version in the report.
  3. Please provide us with the EDID, you can use the OS or a third-party tool.
  4. Did you make sure that Linux Operating systems are supported in your laptop with your System Manufacturer?
Jocelyn M.
Jocelyn_Intel
Hello, @DrRobert
I hope you are well.
Jocelyn M.
Jocelyn_Intel
Hello, @DrRobert
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
