Hello sugars!
I'm having a bit of a problem here!
I've switched from Windows to Linux ( currently running Ubuntu 23.10 ) and i can't seem to be able to set the proper resolution to the external monitor :V
Here are my specs:
Model: Dell Inc. Vostro 3400
CPU: 11th Gen Intel® Core™ i5-1135G7 @ 2.40GHz × 8
GPU: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics]
Monitor: HUAWEI MateView GT 34'' Ultrawide Curved Gaming Monitor, 165Hz, 21:9 WQHD
Just to make things clear un Windows it worked just fine, same cable same port!!
Here's an xrandr log:
xrandr --verbose
Screen 0: minimum 320 x 200, current 6912 x 2160, maximum 16384 x 16384
eDP-1 connected 3072x1728+3840+0 (0x45) normal (normal left inverted right x axis y axis) 309mm x 174mm
Identifier: 0x42
Timestamp: 121361
Subpixel: unknown
Gamma: 0.53:1.0:1.7
Brightness: 0.72
Clones:
CRTC: 1
CRTCs: 1 0 2 3
Transform: 1.599991 0.000000 0.000000
0.000000 1.599991 0.000000
0.000000 0.000000 1.000000
filter: bilinear
_MUTTER_PRESENTATION_OUTPUT: 0
EDID:
00ffffffffffff0038702b0000000000
011c0104951f117802b370985d598e28
1c505400000001010101010101010101
0101010101011a3680a070381f403020
350035ae1000001a522b80a070381f40
3020350035ae1000001a000000fe0056
5030383880313430324c303100000000
0000412196001000000a010a20200007
vrr_capable: 0
range: (0, 1)
Colorspace: Default
supported: Default, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, RGB_WIDE_FIXED, RGB_WIDE_FLOAT, BT601_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
scaling mode: Full aspect
supported: Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 308
supported: 308
non-desktop: 0
range: (0, 1)
1920x1080 (0x45) 138.500MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1920x1080 (0x46) 110.900MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 53.32KHz
v: height 1080 start 1083 end 1088 total 1111 clock 47.99Hz
1680x1050 (0x47) 119.100MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.73KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.93Hz
1400x1050 (0x48) 121.915MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.85KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.93Hz
1600x900 (0x49) 97.677MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.50KHz
v: height 900 start 903 end 908 total 926 clock 59.93Hz
1280x1024 (0x4a) 107.845MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.89KHz
v: height 1024 start 1025 end 1028 total 1066 clock 59.93Hz
1400x900 (0x4b) 86.578MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.50KHz
v: height 900 start 903 end 913 total 926 clock 59.93Hz
1280x960 (0x4c) 107.880MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 59.93KHz
v: height 960 start 961 end 964 total 1000 clock 59.93Hz
1440x810 (0x4d) 151.771MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.85KHz
v: height 810 start 811 end 814 total 833 clock 59.93Hz
1368x768 (0x4e) 72.347MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.35KHz
v: height 768 start 771 end 781 total 790 clock 59.93Hz
1280x800 (0x4f) 71.028MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.33KHz
v: height 800 start 803 end 809 total 823 clock 59.93Hz
1280x720 (0x50) 63.951MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.41KHz
v: height 720 start 723 end 728 total 741 clock 59.93Hz
1024x768 (0x51) 64.924MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.31KHz
v: height 768 start 771 end 777 total 806 clock 59.93Hz
960x720 (0x52) 116.871MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 89.90KHz
v: height 720 start 720 end 722 total 750 clock 59.93Hz
928x696 (0x53) 108.937MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.18KHz
v: height 696 start 696 end 698 total 719 clock 59.93Hz
896x672 (0x54) 102.262MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.55KHz
v: height 672 start 672 end 674 total 697 clock 59.93Hz
1024x576 (0x55) 42.080MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.54KHz
v: height 576 start 579 end 584 total 593 clock 59.93Hz
960x600 (0x56) 76.916MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 73.96KHz
v: height 600 start 601 end 604 total 617 clock 59.93Hz
960x540 (0x57) 37.322MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.32KHz
v: height 540 start 543 end 548 total 556 clock 59.93Hz
800x600 (0x58) 38.357MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 37.46KHz
v: height 600 start 601 end 603 total 625 clock 59.93Hz
840x525 (0x59) 59.550MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.73KHz
v: height 525 start 526 end 529 total 540 clock 59.93Hz
864x486 (0x5a) 30.686MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.97KHz
v: height 486 start 489 end 494 total 500 clock 59.93Hz
700x525 (0x5b) 60.957MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.85KHz
v: height 525 start 526 end 532 total 541 clock 59.93Hz
800x450 (0x5c) 48.838MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.50KHz
v: height 450 start 451 end 454 total 463 clock 59.93Hz
640x512 (0x5d) 53.922MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.89KHz
v: height 512 start 512 end 514 total 533 clock 59.93Hz
700x450 (0x5e) 43.289MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.50KHz
v: height 450 start 451 end 456 total 463 clock 59.93Hz
640x480 (0x5f) 25.172MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
720x405 (0x60) 22.098MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 419 clock 59.93Hz
684x384 (0x61) 36.173MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.35KHz
v: height 384 start 385 end 390 total 395 clock 59.93Hz
640x360 (0x62) 17.932MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.41KHz
v: height 360 start 363 end 368 total 374 clock 59.93Hz
512x384 (0x63) 32.462MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.31KHz
v: height 384 start 385 end 388 total 403 clock 59.93Hz
512x288 (0x64) 21.004MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.48KHz
v: height 288 start 289 end 292 total 296 clock 59.93Hz
480x270 (0x65) 18.661MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.32KHz
v: height 270 start 271 end 274 total 278 clock 59.93Hz
400x300 (0x66) 19.148MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 37.40KHz
v: height 300 start 300 end 301 total 312 clock 59.93Hz
432x243 (0x67) 15.343MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.97KHz
v: height 243 start 244 end 247 total 250 clock 59.93Hz
320x240 (0x68) 12.562MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.41KHz
v: height 240 start 245 end 246 total 262 clock 59.93Hz
360x202 (0x69) 11.023MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 25.05KHz
v: height 202 start 204 end 206 total 209 clock 59.93Hz
320x180 (0x6a) 8.966MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.41KHz
v: height 180 start 181 end 184 total 187 clock 59.93Hz
HDMI-1 connected primary 3840x2160+0+0 (0x6b) normal (normal left inverted right x axis y axis) 797mm x 334mm
Identifier: 0x43
Timestamp: 121361
Subpixel: unknown
Gamma: 0.53:1.0:1.7
Brightness: 0.72
Clones:
CRTC: 0
CRTCs: 1 0 2 3
Transform: 2.000000 0.000000 0.000000
0.000000 2.000000 0.000000
filter: bilinear
EDID:
00ffffffffffff0022f6256a22f680c0
08200103805021780a54b1ac5047a426
115054bfcf0081408180714f81c0b300
d1c0010101014ed470a0d0a046503040
3a001d4e3100001ce77c70a0d0a02950
30203a001d4e3100001a000000fd0030
901ea03c010a202020202020000000fc
005a51452d4341410a202020202001c7
020348f14b1f9014010304121305025a
2309070783010000e200d567030c0010
00384067d85dc4017880006d1a000002
013090e60000000000e305c081e30f00
00e606050166661c565e00a0a0a02950
302035001d4e3100001a9d6770a0d0a0
225030203a001d4e3100001a464714a0
a0381f40302018041d4e3100001a001d
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
max bpc: 12
range: (8, 12)
content type: No Data
supported: No Data, Graphics, Photo, Cinema, Game
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
supported: force-dvi, off, auto, on
link-status: Good
CONNECTOR_ID: 317
supported: 317
non-desktop: 0
range: (0, 1)
1920x1080 (0x6b) 148.500MHz -HSync -VSync *current
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x6c) 148.500MHz +HSync +VSync
1920x1080 (0x6d) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x6e) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1680x1050 (0x6f) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1280x1024 (0x70) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x71) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x72) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1152x864 (0x73) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x74) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x75) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x76) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x77) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x78) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x79) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x7a) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x7b) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x7c) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x7d) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x576 (0x7e) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x7f) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x80) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x81) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x82) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0x83) 30.240MHz -HSync -VSync
h: width 640 start 704 end 768 total 864 skew 0 clock 35.00KHz
v: height 480 start 483 end 486 total 525 clock 66.67Hz
640x480 (0x84) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x85) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x86) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
I then tried to manually set it but i get this error:
robert@robert-Vostro-3400:~$ cvt -r 3440 1440 60
# 3440x1440 59.97 Hz (CVT) hsync: 88.82 kHz; pclk: 319.75 MHz
Modeline "3440x1440R" 319.75 3440 3488 3520 3600 1440 1443 1453 1481 +hsync -vsync
robert@robert-Vostro-3400:~$ xrandr --newmode "mymode" 319.75 3440 3488 3520 3600 1440 1443 1453 1481 +hsync -vsync
xrandr --addmode HDMI-1 "mymode"
robert@robert-Vostro-3400:~$ xrandr --output HDMI-1 --mode "mymode" --verbose
screen 0: 6912x2880 1625x677 mm 108.00dpi
crtc 0: mymode 59.97 +0+0 "HDMI-1"
xrandr: Configure crtc 0 failed
crtc 0: disable
crtc 1: disable
crtc 2: disable
crtc 3: disable
screen 0: revert
crtc 0: revert
crtc 1: revert
crtc 2: revert
crtc 3: revert
If i look at the journalctl logs however it seems that it detects these resolutions ( yes i tried to add one of thise but no success there either )
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Printing DDC gathered Modelines:
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "3440x1440"x0.0 543.50 3440 3488 3552 3600 1440 1443 1453 1510 -hsync +vsync (151.0 >
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "3440x1440"x0.0 319.75 3440 3488 3520 3600 1440 1443 1453 1481 +hsync -vsync (88.8 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "3440x1440"x0.0 265.25 3440 3488 3520 3600 1440 1443 1453 1474 +hsync -vsync (73.7 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "2580x1080"x0.0 182.46 2580 2628 2660 2740 1080 1097 1105 1111 +hsync -vsync (66.6 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vs>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vs>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 k>
Dec 07 18:08:32 robert-Vostro-3400 /usr/libexec/gdm-x-session[2121]: (--) modeset(0): HDMI max TMDS frequency 320000KHz
Hello, @DrRobert
I understand that you are having issues with the resolution 3440x1440, I will do my best to assist you here.
- How is the monitor connected to the laptop?
- Are you using adapters/splitters/docking stations or is it a straight connection (HDMI to HDMI, no adapters)?
- Does this happen with another monitor?
- Please provide the EDID using the operating system or a third-party tool.
- Please attach an Intel SSU report so we can have more information about your system:
Intel® System Support Utility for the Linux* Operating System
Jocelyn M.
Hello, @DrRobert
In addition to the previous post, please try the steps recommended in this forum thread: How do I set a custom resolution?
Please let me know the results or confirm if you already performed them.
Jocelyn M.
Hello, @DrRobert
I hope you are great.
I am checking this thread and I would like to know if you were able to check my previous post.
Jocelyn M.
Hi man! Sorry i was unable to reply in the last couple of days.
I made some progress though it apparently seem to be working now but only if i set a refresh rate of 25 if i set higher than 25 it doesn't work anymore :V
It's connected HDMI to HDMI no adapters or anything, same cable, same port as i had on Windows
Yes i have another 4k monitor ( resolution that should be supported by the integrated GPU but it still can't go beyond 25Hz
I've attatched an SSU report.....since it's working with 25Hz i assume it's a driver issue since with the same setup it was working on WIndows just fine on 60Hz
Hello, @DrRobert
Thank you for your reply.
- Can you please confirm if you tried the steps recommended in this forum thread: How do I set a custom resolution?
- Also, have you installed the driver from your Linux Distribution? The graphics drivers for Linux operating systems are provided by them. I am unable to see the driver version in the report.
- Please provide us with the EDID, you can use the OS or a third-party tool.
- Did you make sure that Linux Operating systems are supported in your laptop with your System Manufacturer?
Jocelyn M.
Hello, @DrRobert
I hope you are well.
Jocelyn M.
Hello, @DrRobert
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
