20629 Discussions
15-bs100ur i5-8x - Need no official Video Driver`s for Windows 8.1 (64)
Hello. i have HP 15-bs100ur i5-8250U
found all drivers for 8.1 64bit, except Intel video card
Switching video and changing the brightness level also does not work.
Help plz!
intel video 620 UHD
PCI\VEN_8086&DEV_5917&SUBSYS_832B103C&REV_07\3&11583659&0&10
AlHill
You have a 8th gen processor. You can only install Windows 10. Anything less is not supported and there are no drivers:
Only Windows 10 is supported on 7th and 8th gen processors.
https://www.intel.com/content/www/us/en/support/articles/000005526/graphics-drivers.html Supported Operating Systems for Intel® Graphics Products
Doc
Unfortunately, the corp. software used on the laptop does not allow you to install windows 10. How can I solve this problem not officially?
AlHill
Only officially supported systems and solutions are found here.
Sorry, your corp should have investigated more thoroughly before buying that laptop. There are plenty of good laptops with 6th gen processors.
Now, one thing you can do is, if you can install windows 10 pro, to use hyper-v and run w8.1 as a virtual machine.
Doc
thanks, everything turned out after editing the info file UND620 works great.
install in the mode of unsigned drivers
