Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
2 displays to motherboard with Intel B150 Chipset
Can i connect 2 display to motherboard with Intel B150 Chipset (MSI B150M MORTAR) and CPU Intel G4560 without installing external videocard? i need to duplicate image. I saw in specification that B150 chipset supports up to 3 displays and G4560 too, but i haven't found any proof about that.
Highlighted
It is not the chipset, but the processor that supports up to 3 monitors:
http://ark.intel.com/products/97143/Intel-Pentium-Processor-G4560-3M-Cache-3_50-GHz Intel® Pentium® Processor G4560 (3M Cache, 3.50 GHz) Product Specifications
It all depends on how your motherboard and BIOS implements the video capability.
Doc
Highlighted
Community Manager
Hello allkatraz,
I understand you would like you know if you can or not setup dual display on your MSI* B150M MORTAR motherboard.
Let me apologize for any inconvenience this issue may be causing to you.
As Al Hill mentioned our graphics controller supports up to three displays. Depending on how the motherboard manufacturer built the motherboard then the amount of monitors that can be used at the same time. Dual display is a common feature so it will be most likely supported with any combination of video ports that come in your motherboard.
The best option would be contacting MSI* directly so they can confirm dual display will work in that specific motherboard model. This link will give you their contact information https://ru.msi.com/about/contact-us https://ru.msi.com/about/contact-us
Let me know if you have or not any other inquiry.
Fred D.
