23269 Discussions
32GB RAM for Core i7-2960XM
Perfect
Hi everyone,
Do you think Core i7-2960XM will accept via dual channel 2X16GB DDR3 1600MHz SODIMM?
AlHill
You need to check with the system/motherboard manufacturer as to the type of memory supported.
Perfect
They noted 8GB but I’m currently running 16GB (2X8GB) at 1866MHz. DELL Precisions series uses 32GB by quad channels and it works but with speed of 1333MHz.
There is no way I can know if 32GB will work unless I gamble by buying it or ask just like I’m doing but hence nobody knows I think the only solution is to gamble it like I did for the current 16GB.
AlHill
Then, you have to gamble.   Personally, I would not bother spending the money on a system with a processor that is more than a decade old.   Save your money, and get a new/newer system that supports an 11th gen or greater processor.
Perfect
Sure, you are right. I’m about to get GPD WIN Max 2. It’s powerful for it’s size and has eventually everything even for it’s size at 10”.
My current laptop we are talking about is so sweet due to its sleek design, feel and the UV backlit keyboard with the eye catching stylish red light keyboard. It’s has a discrete GPU but just 1GB but the current processor is giving me 3.7GHz on 8 cores with VisionTek 16TB SSD installed.
DeividA_Intel
Hello Perfect,
Due to this product was discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
