22382 Discussions
3440x1440 ultrawide support on Samsung Glaxy Book 3 Pro
Sames2772
I am able to connect my Samsung Galaxy 3 Pro to my Ultrawide monitor (21:9) Samsung odyssey G8 Oled (cable is HDMI to Micro HDMI).
However I can not change the output aspect ration and my pc can only output a 16:9 AR which is then stretched by the monitor.
I have downloaded the latest driver 32.0.101.5768 but still can't change it to get the 21:9 AR.
It says below  "This display has a fixed aspect ratio"
My work laptop (dell latitude) was working just fine so it is not a monitor or cable issue.
Can you please help ?
MUC
Valued Contributor III
The HDMI port on your Samsung Galaxy Book3 Pro only corresponds to version 1.4
Please use a Thunderbolt 4 cable to connect the device to the Samsung Odyssey OLED G8 G85SB. This enables 3440 x 1440 @ 120 Hz via the DisplayPort HBR3 protocol.
MUC
If you are located in France, you can also order this cable:
https://www.amazon.fr/Cable-Matters-107032-BLK-1m-USB-Cables/dp/B08YS59V4K
