Before i go and buy the monitor I`d like to ask if this will work for me properly.
I have Latitude 5400 i5-8365U @ 1.60Ghz + 16 RAM + Intel UHD Graphics 620 and Dell K20A001 docking station connected to 2 x Dell P2319H monitors via DisplayPort that is on docking station.
If i buy 35" LG 35WN75CN ultra wide monitor and will connect it to the dock station via display port that is connected to laptop via USB C will it perform properly at full resolution?
Thank you very much for help.
Peter M
Hello funeralfog669,
Thank you for posting on the Intel️® communities. We understand that you are looking to confirm if the new monitor will work on your system. We will be more than glad to help you.
If you are planning to add the monitor to the setup you already have, it may not work. Based on the processor specifications, the maximum number of displays supported by the integrated graphics is three. You have the two Dell P2319H monitors and the embedded display of your laptop. You are currently using the maximum supported display.
However, if you plan to replace one of your monitors with the new one, we advise you to contact Dell support for further compatibility information.
Best regards
Jean O.
Hello Jean O.,
I apologize i realized that i have not expressed myself correctly.
What i plan to do is to replace the 2 Dell monitors i have connected to docking station with the new 1 ultra wide monitor..
So it will be just embedded laptop display + 1x ultra wide monitor 35" LG 35WN75CN connected via DisplayPort at the docking station..
Would that work properly with the resolution 3440 × 1440 etc..?
Again, many thanks for finding your time to reply.. much appreciated.
Peter M.
In theory, it should work just fine - unless the laptop vendor screwed things up and the screen size is artificially limited by the embedded display size (hint: just in case, make sure you have installed the latest BIOS update that the vendor has released).
Hope this helps,
We hope you are doing fine.
Best regards.
Jean O.
