22118 Discussions
4k or 2k support for Intel i5 HD520?
BKor
I am buying a monitor (interested in lg27ul550-w)  and I am not sure if I am able to use 4k or 2k resolution provided by LG.
My computer :
Graphics card is an HD520, in an HP EliteBook 840 G3
Processor: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
Can you help me to clarify the situation about having the monitor  (lg27ul550-w, but also others) with higher resolutions, before actually buying it?
Borut
(I attached SSU file too, if that helps)
(Virus scan in progress ...)
n_scott_pearson
If your laptop only has an HDMI connector, it may be limiting your capability. If you have a DisplayPort connector, on the other hand, you can establish a 4K@60Hz connection. I am accomplishing this using an Intel NUC6i5SYH (Core i5-6260U processor) and a 4K@60Hz-rated mDP-to-HDMI adapter. I am outputting to a 43" Samsung 6000 Series TV.
Hope this helps,
BKor
Thank you so much for your kind answer.
I have a display port on the computer, so I believe it will work.
Do I have to pay attention to possible different kinds (if there are at all) of display ports?
Borut
n_scott_pearson
Yes, there are two different connectors that you possibly might have, standard and mini. See https://en.wikipedia.org/wiki/DisplayPort for more information.
BKor
