22928 Discussions
4k with HD 4600
Anonymous
Non applicable
2 617 Visites
Hi community,
I have a i7 4785 T on a ASUS Gene VII board which has only a HDMI port.
I would like to run a 4K display at 60 Hz with it.
Is UHD with 60 Hz possible via a HDMI-cable?
I know the data-sheet says: Max Resolution (HDMI)4096x2304@24Hz
If "no" would a (active) adapter HDMI to DP make UHD with 60 Hz possible?
Because the data-sheet says Max Resolution (DP)‡3840x2160@60Hz
Thank you for your time and help. 🙂
0 Compliments
4 Réponses
n_scott_pearson
Super utilisateur
2 604 Visites
No, you are stuck with HDMI 1.4 and only 2160p@30Hz. If fact, it is rare to find a motherboard whose HDMI port can support better than 1080p@60Hz. The implementations back then were poor.
No, you can't make a 60Hz HDMI output from a 30Hz HDMI input; it simply isn't possible.
The only way to get 4K@60Hz on your machine would be via a DisplayPort 1.2 port, either one provided directly or secondarily via Thunderbolt. If you motherboard doesn't provide one of these ports, you are simply out of luck.
Sorry, reality bites,
0 Compliments
Anonymous
Non applicable
2 591 Visites
Thank you for your answer.
Did I get it right, that in my case the board respectively the HDMI 1.4 port on it is the limiting factor?
So if the board manual says:
HDMI with max. resolution 4096x2160@24Hz / 2560x1600@60Hz
I can at least have QHD 2560 x 1440@60Hz with my hardware or does it exactly have to be 2560x1600@60Hz?
Would 4k@24 Hz in general be to poor to watch movies with it?
0 Compliments
n_scott_pearson
Super utilisateur
2 567 Visites
Nothing that you have said is wrong, per se, but I will say that I have seen reports of these older drivers having problems with the QHD/WQHD resolution - and I have never had such a monitor to try this myself so I can't say one way or the other.
I can only say that my eyes don't want to watch at 24Hz - or even 30Hz if I can avoid it. I say get yourself an add-in video card that can give you 4K@60Hz.
0 Compliments
Anonymous
Non applicable
2 555 Visites
Thanks for your advice ... I will think this over.
The thing is that I have to calculate a little bit before buying a video card of lets say 20 W.
I have a 120 W power supply.
i7 4785t needs 35 W + "x"
Mainboard needs ~ 15 W
SSD ~ 5 W
Ram ~ 5 W
The question is how much is "x" with the i7 4785t in Windows 10 Balanced Mode. Do you by chance know something about it?
0 Compliments
Répondre
