23558 Diskussionen
945GM express and OpenGL issues
Mitarbeiter
2.133Aufrufe
I hope someone can help!
I tried to use some features on my CS4 and kept getting an error that OpenGL was not enabled, so when I tried to enable it, it was grayed out. I tried to upgrade my video card/driver and that didn't help either. I then went to the Adobe website and got the OpenGL plug-in, that did not work either. (the OpenGL option is still grayed out and it's telling me my driver or whatever does not support OpenGL)
Is it possible to install a different driver and have 2 or will it mess up my laptop? I have the Moble Intel(R) 945GM Express Chipset Family. Any and all help with this would be greatly appreciated!
More info: OK I just googled if my driver supports OpenGL now so I tried to upgrade directly from the Intel website and got this message:
Product Detected http://www.pilo.me/redirect-to/?redirect=http://www.intel.com/support/graphics/intel945gm/index.htm Mobile Intel® 945 Express Chipset Family Current Driver Installed 7.14.0010.1147 A customized computer manufacturer driver is installed on your computer. The Intel Driver Update Utility is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer.
Does this mean that I'm screwed? Or can I go ahead and install the generic driver? I'm clueless about this!!!!!
1 Antworten
Mitarbeiter
1.299Aufrufe
I have the same problem...
I can not get OpenGL 2.0 programs to run...
I am using a HP Mini 110-1100 Netbook with Windows7 Starter
Video Card Vendor: Intel
Renderer: Intel 945GM
OpenGL Version: 1.4.0 - Build 8.14.10.1930
GLU Version: 1.2.2.0 Microsoft Corporation.
I have TRIED to run Intel® Graphics Media Accelerator Driver for Windows* 7(exe) win7_1512754 driver version 15.12.75.4.1930 (8.15.10.1930) and still does not work.
Current pixel format: 6
Pixel Formats supported by this video card
# Type Flags Buf Type Color(R-G-B-A) Z-Depth Stencil Accum(R-G-B-A)
1 ICD 00008024 SGL RGBA 32 (8-8-8-8) 0 0 0(0-0-0-0)
2 ICD 00008025 DBL RGBA 32 (8-8-8-8) 0 0 64(16-16-16-16)
3 ICD 00008024 SGL RGBA 32 (8-8-8-8) 16 0 0(0-0-0-0)
4 ICD 00008025 DBL RGBA 32 (8-8-8-8) 16 0 64(16-16-16-16)
5 ICD 00008024 SGL RGBA 32 (8-8-8-8) 24 8 0(0-0-0-0)
6 ICD 00008025 DBL RGBA 32 (8-8-8-8) 24 8 64(16-16-16-16)
7 GEN 0000807C SGL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
8 GEN 0000807C SGL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
9 GEN 00008465 DBL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
10 GEN 00008465 DBL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
11 GEN 0000807C SGL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
12 GEN 0000807C SGL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
13 GEN 00008465 DBL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
14 GEN 00008465 DBL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
15 GEN 0000807C SGL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
16 GEN 0000807C SGL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
17 GEN 00008465 DBL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
18 GEN 00008465 DBL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
19 GEN 00000078 SGL RGBA 24 (8-8-8-0) 32 8 64(16-16-16-0)
20 GEN 00000078 SGL RGBA 24 (8-8-8-0) 16 8 64(16-16-16-0)
21 GEN 00000078 SGL RGBA 24 (8-8-8-8) 32 8 64(16-16-16-16)
22 GEN 00000078 SGL RGBA 24 (8-8-8-8) 16 8 64(16-16-16-16)
23 GEN 00000078 SGL CI 24 (8-8-8-0) 32 8 0(0-0-0-0)
24 GEN 00000078 SGL CI 24 (8-8-8-0) 16 8 0(0-0-0-0)
25 GEN 00000078 SGL RGBA 16 (5-5-5-0) 32 8 32(11-11-10-0)
26 GEN 00000078 SGL RGBA 16 (5-5-5-0) 16 8 32(11-11-10-0)
27 GEN 00000078 SGL RGBA 16 (5-5-5-8) 32 8 32(8-8-8-8)
28 GEN 00000078 SGL RGBA 16 (5-5-5-8) 16 8 32(8-8-8-8)
29 GEN 00000078 SGL CI 16 (5-5-5-0) 32 8 0(0-0-0-0)
30 GEN 00000078 SGL CI 16 (5-5-5-0) 16 8 0(0-0-0-0)
31 GEN 00000078 SGL RGBA 8 (3-3-2-0) 32 8 32(11-11-10-0)
32 GEN 00000078 SGL RGBA 8 (3-3-2-0) 16 8 32(11-11-10-0)
33 GEN 00000078 SGL RGBA 8 (3-3-2-8) 32 8 32(8-8-8-8)
34 GEN 00000078 SGL RGBA 8 (3-3-2-8) 16 8 32(8-8-8-8)
35 GEN 00000078 SGL CI 8 (3-3-2-0) 32 8 0(0-0-0-0)
36 GEN 00000078 SGL CI 8 (3-3-2-0) 16 8 0(0-0-0-0)
37 GEN 00000078 SGL RGBA 4 (1-1-1-0) 32 8 16(5-6-5-0)
38 GEN 00000078 SGL RGBA 4 (1-1-1-0) 16 8 16(5-6-5-0)
39 GEN 00000078 SGL RGBA 4 (1-1-1-8) 32 8 16(4-4-4-4)
40 GEN 00000078 SGL RGBA 4 (1-1-1-8) 16 8 16(4-4-4-4)
41 GEN 00000078 SGL CI 4 (1-1-1-0) 32 8 0(0-0-0-0)
42 GEN 00000078 SGL CI 4 (1-1-1-0) 16 8 0(0-0-0-0)
OpenGL extensions found for the current pixel format
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_blend_color
GL_EXT_abgr
GL_EXT_texture3D
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_cull_vertex
GL_SGIS_texture_edge_clamp
GL_SGIS_generate_mipmap
GL_EXT_draw_range_elements
GL_SGIS_texture_lod
GL_EXT_rescale_normal
GL_EXT_packed_pixels
GL_EXT_separate_specular_color
GL_ARB_multitexture
GL_EXT_texture_env_combine
GL_EXT_bgra
GL_EXT_blend_func_separate
GL_EXT_secondary_color
GL_EXT_fog_coord
GL_EXT_texture_env_add
GL_ARB_texture_cube_map
GL_ARB_transpose_matrix
GL_ARB_texture_env_add
GL_IBM_texture_mirrored_repeat
GL_EXT_multi_draw_arrays
GL_NV_blend_square
GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1
GL_EXT_texture_filter_anisotropic
GL_ARB_texture_border_clamp
GL_ARB_point_parameters
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar
GL_EXT_texture_compression_s3tc
GL_ARB_shadow
GL_ARB_window_pos
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_ARB_vertex_program
GL_ARB_fragment_program
GL_EXT_stencil_two_side
GL_ARB_vertex_buffer_object
GL_EXT_texture_lod_bias
GL_NV_texgen_reflection
GL_ARB_depth_texture
GL_WIN_swap_hint
Antworten
