- What is the model of your Compute Stick?
- What is the version of the installed Graphic Driver?
Leon
Thanks for prompt reply. Most of computers in our company are dell. my computerəs Graphic card version is 8.15.10.2418. NOte: not all computers shows such error. few computers blok that bat file
- I asked what is your Compute Stick model, since you post your question in Compute Stick Forum (probably not the best place for this question).
- Similar questions has been raised in Intel Graphic Forum in the Past (since this .bat file is created by the Graphic Driver). For example: https://forums.intel.com/s/question/0D50P0000490BrLSAU/what-is-file-a6d608f00bde491a97ae5c4b05d86e01... , https://forums.intel.com/s/question/0D50P0000490CD0SAM/a6d608f00bde491a97ae5c4b05d86e01bat-keeps-get... , https://forums.intel.com/s/question/0D50P0000490MJVSA2/how-disable-a6d608f00bde491a97ae5c4b05d86e01b...
- I believe that it happens only in the old driver versions. So, I suggest that you try to install the latest DCH Graphic driver:
- Download the latest DCH driver: https://downloadcenter.intel.com/download/28731/Intel-Graphics-Windows-10-DCH-Drivers?product=80939
- Disconnect your computer from Internet.
- Open Device Management and uninstall the currently installed Graphic Driver. Mark the "Delete" option in order to delete the old driver from your PC. Reboot your PC.
- Repeat paragraph 6, till you see Basic Microsoft Graphic Driver, shown in Device Manager.
- Install The Last DCH Graphic Driver (previously downloaded).
- Reconnect the Internet and reboot your PC.
- If the DCH driver will not work correctly (since, could be, that your need OEM driver), install the latest driver from Dell site.
Leon
Thank you so much. Wouldn happen any problem if i block that bat file until i install new version of driver?
- You can't simply block it. It will be back again.
- Founded this solution on net: https://www.tenforums.com/graphic-cards/100197-intel-graphics-bat-file.html
Leon
thanks for your help.
