20985 Discussions
A750 Unable to use Adobe Photoshop 2023
magicsky126128
Unable to use Adobe Photoshop 2023,After opening, the system directly freezes
Jean_Intel
Hello magicsky126128,
For this issue, we recommend you uninstall the current driver using Display Driver Uninstaller. Check How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver for instructions. Once you run the tool, you should install our latest driver, 31.0.101.4369. Files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected.
Also, in case the issue persists and to better assist you, please provide me with the following information:
  • Is the issue present on other driver versions?
  • Is rebar enabled?
  • We would like to gather more information about your system, so please create a system report using the Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
Best regards
Jean O.
Jean_Intel
We hope you are doing fine.
Jean O.
Jean_Intel
Best regards.
Jean O.
