22989 Discussions
ASUS P8Z77-V LK - Dual Monitors with HD4000 - HDMI and VGA
entilza
I just setup a new P8Z77-V LK system with a dual Monitor setup with HDMI and VGA ports.
When using windows 8 "Power options" - Turn display off: 10 minutes. Only the VGA monitor goes to standby, the HDMI monitor just gets a black screen. It recovers fine on resume.
When the whole computer goes to full standby (sleep) both monitors get the standby signal which is good.
The HDMI monitor is identified as "Digital Television" and the VGA is classified as a "Monitor"
The only other option I have is to get a DVI->HDMI cable and hope that works, but I bought an HDMI->HDMI cable without even thinking this would not work... Actually in single monitor mode it did not get the standby signal either with the "turn display off: 10 minutes" . Which really shows it's just an HDMI-HDMI issue.
I am using the latest drivers as of Sep 2013.
entilza
I was doing some searching it seems to be the exact issue as in this thread regarding the backlight:
/message/206138# 206138 https://communities.intel.com/message/206138# 206138
I haven't tried the beta drivers, however it looks like it may be solved with those?
Do the beta drivers work with windows 8? Or should I just wait until 8.1 is released?
Kevin_M_Intel
Hi entilza,
This issue is being handled by Diego_Intel in this thread:
/thread/44742?start=15&tstart=0 https://communities.intel.com/thread/44742?start=15&tstart=0
My best recommendation is to follow up in that thread. As per your question Win 8 and Win 8.1 have a similar platform but not the same one so you can try installing the Win 8 drivers at the moment while we come up with the Win 8.1 drivers.
