23501 Discussions
Access violation in glLinkProgram using sampler2D texture[] array
ulassi
I am running into driver Access violation when trying to link a vertex and fragment program in OpenGL.
Platform is Windows 11 Pro v 22H2
OpenGL context information:
OpenGL version string: "4.6.0 - Build 31.0.101.4575".
OpenGL version: 4.6.
Vendor: Intel
Card name: Intel(R) Iris(R) Xe Graphics
Card version: 4.6.0 - Build 31.0.101.4575
Fragment shader:
#version 120
// Repro requirements to fail on intel
// 1. texture array uniform inside a struct
// 2. array passed to function where it is indexed
struct Structure {
sampler2D textures[6];
uniform Structure u_data;
float sample(in sampler2D array[6], in vec2 texcoord) {
return texture2D(array[0], texcoord).x;
void main() {
float s = sample(u_data.textures, vec2(0.0));
gl_FragColor = vec4( s );
 Vertex shader:
#version 120
void main() {
vec4 viewPosition = gl_ModelViewMatrix * gl_Vertex;
gl_Position = gl_ProjectionMatrix * viewPosition;
If I index the array directly in the main method or if I move the uniform textures out from the structure and use it the linking passes. So this seems to be a combination of GLSL language features that provokes the crash.
Jose_Intel
Hello @ulassi
Thank you for posting on the Intel️® communities.
We understand you are experiencing issues with Intel® Iris® Xe Graphics, we will be more than happy to assist you.
Please download the latest graphics driver 31.0.101.4900. Then, use the Display Driver Uninstaller (DDU). After that, please install the latest driver previously downloaded.
Please make sure you run Windows update and your BIOS is up to date (contact your system manufacturer).
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Jose_Intel
Hello ulassi
We hope you are doing fine.
Were you able to clean install the latest graphics driver and update the system?
Let us know if you still need assistance by attaching the required report.
Jose B.
ulassi
Hi, sorry for the delay. But I managed to install the new driver as per your instructions. This is still an issue on that driver. You can find the report you requested attached to this message.
Best,
Urban
Jose_Intel
Hello ulassi
We are sorry that after the steps taken the issue persists. Please answer the following:
·      Do you work for or represent a software company?
·      Are you developing a game or an app?
·      Have you tried using a third-party GPU to replicate the issue?
Jose B.
ulassi
* Yes I work for a company, this issue was discovered while developing for this company.
* We develop a desktop application
* This issue is not reproducible on neither Nvidia or AMD GPU:s.
Jose_Intel
Hello ulassi
Thank you for your replay.
Is it possible for you to share the application you are developing? As well the steps to try to reproduce the issue.
Please let us know, we would like to further investigate.
Jose B.
ulassi
I can share an executable that reproduces the issue. Can you contact me on my email and I can share an archive with you.
Jose_Intel
Hello ulassi
Thank you for the confirmation.
I will contact you privately.
Jose B.
Jose_Intel
Hello ulassi
Did you receive my email?
Let us know if you still need assistance by sending the required information.
Jose B.
ulassi
Yes I did, and I did respond by sending an archive of binaries. Did you not receive anything?
Jose_Intel
Hello ulassi
Thank you for letting us know.
Unfortunately, we did not receive your reply. Could you please reply my previous email with the files again?
Jose B.
Jose_Intel
Hello ulassi
Were you able to send the information again?
Jose B.
ulassi
I did send an email to the adress again.
Is there anything that could block a zip archive from being transmitted?
Jose_Intel
Hello ulassi
We appreciate your response.
Allow us to check more options internally, to try to get the files from you. We will post back as soon as we have any information.
Jose B.
Jose_Intel
Hello ulassi
Thank you for patiently waiting.
After checking, we only have 2 methods (forum and email). Is there any cloud method you consider secure?
Please let us know.
Jose B.
ulassi
I sent another reply to the adress, this time with a link to a shared file.
Hope that one does it :).
Best,
ulassi
Jose_Intel
Hello ulassi
We have an update on this matter.
We received your files and tried to replicate the issue in our lab. However, we have different results.
Since we were able to get the output “Compile sucessful, linking... Test Program Linked sucessfully!”, according to the information you provided, it means that it worked for us.
We will send an email with some more information. We highly recommend checking with the app developers. Please note that this case will no longer be monitored by Intel.
Jose B.
ulassi
We have a workaround for this implemented in our application, the repro app basically uses the same code above with some of our setup libs to reproduce this (not in your lab it seems though).
For anyone interested, the workaround is not passing the array sampler as function parameter:
float sample(
in sampler2D tex0,
in sampler2D tex1,
in sampler2D tex2,
in sampler2D tex3,
in sampler2D tex4,
in sampler2D tex5,
in vec2 texcoord) {
// sample the 6 textures here
void main() {
float s = sample(
u_data.textures[0],
u_data.textures[1],
u_data.textures[2],
u_data.textures[3],
u_data.textures[4],
u_data.textures[5],
vec2(0.0));
