I have reinstalled Windows 7 (x86) on my Acer Aspire 1430. I went to install the latest drivers and rebooted. Now, I get a BSoD whenever I boot up. I can only boot back into safe mode, roll back the drivers and use the default Windows driver.
STOP Error Details:
(igdkmd32.sys)
BCCode: 116
BCP1: 8A0C6510
BCP2: 9645CA70
BCP3: 00000000
BCP4: 00000002
System:
Acer Aspire 1430
Intel i3-380UM 1.33 GHz
Intel Mobile 5 Series chipset / Intel GMA HD (GM965 / PM965 ?)
Win 7 SP 1 (x86)
Driver v8.15.10.2361
This is killing me!
Just to confirm, what happens to your system if you use the driver that has been directly provided by Acer? Are you able to boot properly to the operating system?
If not, you could be having either a hardware problem or the operating system has been corrupted.
If yes, the issue could be a compatibility problem with our generic drivers.
Keep in mind that we provide generic drivers for the video controllers we designed, however your Original Equipment Manufacturer may alter the features on them, so they provide customized drivers to support those changes.
The same thing.
I boot up with a blank screen, a bit if flashing, then BSoD 0x116 after a minute.
I used the Acer drivers first then I used yours (Intel) thinking that would fix the problem.
I have since "bit the bullet" and switched to x64 edition of Windows 7 which doesn't have this problem.
The copy of Windows 7 (x86) had a modified version of the kernel based on:
http://www.geoffchappell.com/viewer.htm?doc=notes/windows/license/memory.htm http://www.geoffchappell.com/viewer.htm?doc=notes/windows/license/memory.htm
(this is the A-HA moment).
