22003 Discussions
Adaptive Sync Inactive
Mohotsi
My Adaptive Sync options for Arc(TM) A370M are greyed out under the Display - Global Settings.
My Drivers are up to date, but can't turn adaptive sync on or unlock FPS.
Please Help.
MUC
Valued Contributor III
Please specify the manufacturer and model of your device.
Please also create a Report for Intel Graphics Drivers and attach the output file here.
Mohotsi
It's the Lenovo YOGA 7
Report Date: Friday, 13 December 2024
Report Time [hh:mm:ss]: 09:35:33 AM
Operating System: Microsoft Windows 11 Home 10.0.22631
IGCC Version: 1.100.5688.0
Language: en-ZA
Physical Memory: 31.73 GB
Current Resolution: 2560x1600
Processor: 12th Gen Intel(R) Core(TM) i7-12700H
Processor Speed: 2300 MHz
GFX Driver Name: Intel(R) Arc(TM) A370M Graphics
Shader Version: 6.6
OpenCL* Version: 3.0
* Microsoft DirectX* *
Runtime Version: 12
Hardware-Supported Version: 12
Vendor ID: 8086
Device ID: 5693
Device Revision: 05
GFX Driver Version: 32.0.101.6319
Dedicated RAM: 4 GB
Shared RAM: 16 GB
Max Supported Displays: 0
GFX Vulcan: 1.3.297
Option ROM (OpROM) Version: 20.0.1045.0
GFX Driver Name: Intel® Iris® Xe Graphics
Shader Version: 6.6
Runtime Version: 12
Vendor ID: 8086
Device ID: 46A6
Device Revision: 0C
Dedicated RAM: 128 MB
Shared RAM: 16 GB
Max Supported Displays: 4
GFX Vulcan: 1.3.297
GFX GOP: 21.0.1046
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Display 1 *
Display Name: Built-In Display
Display Type: Digital
Serial Number: -
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Maximum Image Size
Horizontal - 13.39 inches
Vertical - 8.66 inches
Supported Modes
2560 x 1600 (60p Hz)
Power Management Support
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE 9A 8A 00 00 00 00
1F 1F 01 04 A5 22 16 78 03 47 A5 A8 55 48 9E 25
0E 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 0C 6C 00 A0 A0 40 5E 60 30 20
AA 00 58 D7 10 00 00 18 00 00 00 FD 00 30 3C 66
66 1C 01 0A 20 20 20 20 20 20 00 00 00 FE 00 4C
45 4E 4F 56 4F 0A 20 20 20 20 20 20 00 00 00 FE
00 4C 45 4E 31 36 30 57 51 58 47 41 20 20 00 B9
* Other names and brands are the property of their respective owners.
MUC
The analysis of the EDID shows that this screen only supports a fixed refresh rate of 60 Hz.
That's why you can't enable Adaptive Sync. Has it ever worked on this device or is there any reason to believe it should work?
Mohotsi
I had some frame rate issue, but it seems stable again. I came across adaptive sync and thought it would improve my frame rate capability, I just didn't understand why I couldn't enable it. At least now I know why.
Thank you.
